Click to visit BT.com
Veho Slide & Negative Scanner for 35mm & 110 Instamatic Negatives
1 in stock
Quicklinx: 7KQKWS00
Mfr#: VFS-002m
£38.98
The VFS-002M is Mac compatible and comes with 35mm & 110mm slide and negative trays. Convert your old memories onto your PC ready for editing, archiving, restoring or printing.
Transfer your old 35mm negative film and slides and 110mm instamatic negatives onto your PC/Notebook/Mac ready for editing, archiving or printing. A simple plug and play scanner with no driver to install and fast one touch scanning making it easy to bring those old pictures back to life. Perfect for restoring all those old cherished memories and moments back into the digital world and sharing by email or Facebook. If you want to remove redeye or enhance your image in anyway then simply use the bundled Arcsoft Mediaimpressions software. This is the first scanner to be capable of scanning 110mm negatives.
Image gallery
Select any thumbnail below to view a larger image.
Veho VFS-002M Colourbright - film scanner (35 mm)
Film scanner (35 mm) - desktop
Max Supported Document Size
Film 135 (35mm)
9.3 cm x 7.7 cm x 10 cm
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
1400 dpi
Interpolated Resolution
1800 dpi x 3600 dpi
Supported Document Type
Slides, film
Interface Type
Hi-Speed USB
Microsoft Windows XP, Apple MacOS X 10.3.4 or later, Microsoft Windows Vista (32/64 bits)
Film 135 (35mm)
9.3 cm
7.7 cm
10 cm
Scanner
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
1400 dpi
1800 dpi x 3600 dpi
Scan Element Type
CMOS
Scanner Features
Powered by USB port
Media Handling
Slides, film
1 x Hi-Speed USB
Plug and Play
Software Included
ArcSoft MediaImpression
feature value
Type Film scanner (35 mm)
Form Factor Desktop
Max Paper Size Film 135 (35mm)
Interface Hi-Speed USB
Compatibility Mac
Compatibility PC
Brand Veho
Stock Status In Stock
Price Range Inc VAT 0 - 50
