Click to visit BT.com
Veho Pebble XT 5000mAH Portable Battery Pack Charger
Usually dispatched within 3 working days
Quicklinx: 7KQJWS00
Mfr#: VCC-A008-PBP-XT
£28.88
The powerful Veho Pebble portable battery charger is the must have accessory to keep all your mobile devices full of charge. It packs a massive 5000Ma which is 4 times the regular battery of the Apple iPhone which means it will keep your devices on the go and you won't have to worry about running low on juice. The Pebble is perfect for festivals, camping trips, travelling abroad or as an emergency power pack for those busy days when your device battery just can't keep up. The pebble will charge almost any portable device with connectors for iPhone/iPod/Blackberry/Most Mobile phones (check technical details for long list of devices)/USB charged devices/Veho Muvi and Kuzo range or even the kids gaming devices. Simply charge your Pebble up via USB and use the various adapters to keep all your mobile devices charged up.
Image gallery
Select any thumbnail below to view a larger image.
Veho Pebble XT portable battery pack charger - external battery pack
External battery pack
- 5000 mAh
Apple iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Retractable cable
Voltage Provided
3.7 V
5000 mAh
10 connector tips, carrying pouch
1 x USB charge cable - external
Apple iPad 1 , Apple iPad 2 , Apple iPhone 3G, 3GS, 4, 4S , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G) , Apple iPod touch (1G, 2G, 3G, 4G)
feature value
Type Rechargeable
Size [N/A]
Brand Veho
Price Range Inc VAT 0 - 50
