Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
Veho 360 WHITE M4 BLUETOOTH SPEAKER
Quicklinx: 93TGWS00
Mfr#: VSS-747-360BT
£28.94
Essential accessories
The 360° M4 Bluetooth Speaker follows on from the successful VSS-006-360BT 360° M3 Bluetooth Speaker but introduces duel 2 x 2.2 w speaker power and includes a microSD card slot and volume/track control.
The 360° M4 Bluetooth Wireless Speaker remains totally portable standing only 6.5 cm high with a diameter of 5.5 cm and contains a 600 mAh rechargeable battery that allows playback of up to 6 hrs. The M4 also ships with a standard 3.5 mm line in cable to use with any standard non Bluetooth device, mini USB charging cable and also a funky protective carry sock.
Sound output on the 360° M4 Bluetooth Wireless Speaker is doubled boosted by two 2.2 watt speakers and for convenience volume and track control are located on the speaker so you can control your music from the speaker whether you are using Bluetooth wireless or the micro SD port located on the speaker.
Veho 360 M4 Bluetooth Wireless Speaker - speaker - for portable use - wireless
Speaker - portable
Integrated Components
microSD card reader
6.5 cm
Dimensions - Diameter
5.5 cm
Speaker Type
Active
Nominal Output Power (Total)
4.4 Watt
Connectivity Interfaces
Bluetooth
Supported Digital Audio Standards
MP3, WMV (Sound)
Speaker Details
Speaker - stereo - 2 x 2.2 Watt - active
Ice white
Speaker battery - rechargeable - Lithium Ion
Speaker - for portable use
microSD card reader
6.5 cm
5.5 cm
Enclosure Colour
Ice white
Speaker System
Speaker Type
Active
4.4 Watt
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Built-in Devices
microSD card reader
MP3, WMV (Sound)
Controls
Volume
Additional Features
USB charging
Speaker System Details
Speaker Details
Connector Type
Audio line-in ( mini-phone stereo 3.5 mm )
Audio cable, protective case, USB charging cable
600 mAh
Run Time (Up To)
6 hour(s)
Power: 4.4Watt
Brand: Veho
Price Range Inc VAT: 0 - 50
