Click to visit BT.com
U S Robotics USRobotics 56K PCI Faxmodem - Fax / modem - plug-in card - PCI - 56 Kbps - V.90, V.92
U S Robotics U S Robotics USRobotics 56K PCI Faxmodem - Fax / modem - plug-in card - PCI - 56 Kbps - V.90, V.92
Usually dispatched within 3 working days
Quicklinx: 49T3WS00
Mfr#: USR805671
£17.78 inc VAT
The U.S. Robotics 56K PCI Faxmodem utilizes the processing power of your home computer to make sending / checking e-mail and surfing the Web easy. Update your home computer to surf the Web, send / receive e-mail, and take incoming calls while online with the ease and convenience of V.92 technology. Need to send a batch of digital pictures or other e-mail attachments? V.92 lets you send attachments up to 50% faster! Quick Connect lets you establish your connection faster, so you spend less time dialing up. You're only seconds from surfing the Web!
USRobotics 56K PCI Faxmodem - fax / modem
Fax / modem - PCI ( PCI 2.2 )
Enclosure Type
Plug-in card
2.2 cm x 13.3 cm x 12.1 cm
200 g
Max Transfer Rate
56 Kbps
Protocols & Specifications
ITU V.29, ITU V.34, ITU V.90, ITU V.17, ITU V.27ter, ITU V.92, ITU V.80
Max Fax Transfer Rate
14.4 Kbps
Error Correction Protocol
MNP-4, ITU V.42, MNP-2, MNP-3
Data Compression Protocol
MNP-5, ITU V.42bis, ITU V.44
Microsoft Windows 95, Microsoft Windows 98/ME/2000/XP
2 years warranty
Fax / modem
Enclosure Type
Plug-in card
2.2 cm
13.3 cm
12.1 cm
200 g
Modem
Interface Type
PCI
PCI Revision
PCI 2.2
Wired
Max Transfer Rate
56 Kbps
56K Technology
V.90, V.92
14.4 Kbps
1 x modem - phone line - RJ-11
Compatible Slots
1 x PCI
1 x phone cable - 2.1 m
RoHS
Software Included
Drivers & Utilities
System Requirements Details
Pentium - 233 MHz - RAM 32 MB - HD 5 MB
2 years warranty
Service & Support Details
feature value
Type Fax / modem
Enclosure Plug-in card
Interface PCI
Compatibility PC
Brand U S Robotics
Price Range Inc VAT 0 - 50
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
