Trust's GXT 27 racing wheel has a vast array of buttons which allow convenient and advanced gaming on either the Sony PlayStation 3 or the PC. This sturdy, robust gamepad comes with an 8 way gamepad, 2 analog sticks and 15 buttons. These buttons consist of the standard PlayStation buttons (X, Circle, Triangle and Square) and also the 2 sets of shoulder buttons. There are also controls for Start, Select, Clear and Home button. One of the useful additional buttons is the Turbo control which is a huge advantage for games which require rapid fire action.
The Trust GXT 27 racing wheel is a compact set of wheel and pedals so that it can be conveniently used in rooms with a limited space available. It comes with a sturdy mount and suction cup for rock solid table mounting.
As with using this racing wheel on a PC, all that is required to use on a PlayStation is simply plugging it into one of the USB ports. Whilst being used in a PlayStation 2 or 3, this racing wheel can benefit from pressure sensitive buttons to ensure a realistic gaming experience. The main buttons you find on the steering wheel are similar to the ones you would find on the PlayStation such as the traditional X, Circle, Square and Triangle as well as the 4 shoulder buttons.
Towards the bottom of the steering wheel you will find the Home button as well as the Start and Select key.
Product Description | Trust Compact Vibration Feedback Steering Wheel PC-PS2-PS3 GM-3200 - wheel and pedals set - wired | Product Type | Wheel and pedals set | Connectivity Technology | Wired | Pointing Device / Manipulator | 2 gear shift levers | Features | Table mounts, vibration, rubber coating | Manufacturer Warranty | 2-year warranty | Designed For | PC, Sony PlayStation 3 |
General | |
Interface | USB |
Game Controller (1st) Details | |
Type | Wheel |
Buttons Qty | 12 |
Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
System Requirements | |
OS Required | Microsoft Windows Vista / XP |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
