Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
TP LINK TP-Link MC200CM - fibre media converter - 1GbE
£32.62
24 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Complies with IEEE 802.3ab and IEEE 802.3z
  • Link fault passthrough and far end fault minimize the loss caused by link failure timely
  • Provides switch configuration of force /auto transfer mode for FX port
  • Extends fiber distance up to 0.5km
  • Supports auto MID/MID-X for TX port
  • Easy-to-view LED indicators provide status to monitor network activity easily
  • Type: Media Converter
Product codes
chevron icon
chevron icon
The MC200CM is a media converter designed to convert 1000BASE-SX fiber to 1000Base-T copper media or vice versa. Designed under IEEE802.3ab 1000Base-T and IEEE802.3z 1000Base-SX standards, the MC200CM is designed for use with multi-mode fiber cable utilizing the SC-Type connector. The MC200CM supports shortwave (SX) laser specification at a full wire speed forwarding rate. It works at 850nm on both transmitting and receiving data.
Other features of this module include the ability to be used as a stand alone device (no chassis required) or with TP-LINK's 19'system chassis, Auto MDI/MDI-X for TX port, and front panel status LEDs. The MC200CM will transmit at extended fiber optic distances utilizing multi-mode fiber up to 0.55 kilometers.
chevron icon
Product Description TP-Link MC200CM - fibre media converter - 1GbE
Device Type Fibre media converter - RJ-45 / SC multi-mode
Form Factor External
Cabling Type 1000Base-SX, 1000Base-T
Data Transfer Rate 1 Gbps
Optical Wave Length 850 nm
Data Link Protocol 1GbE
Max Transfer Distance 550 m
Dimensions (WxDxH) 9.5 cm x 7.3 cm x 2.7 cm
Designed For P/N: TL-MC1400, TL-SG3210XHP-M2 V2.6, TL-SG3452XP V1
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£32.62
