Immersive lighting for any scenario
Easily design scenarios for your daily routine or special activities by customizing brightness, color temperature (2,500-6,500 K), and colors—with 16,000,000 hues to choose from.
Adjust with Ease
Manage the lighting at your fingertips to create the perfect atmosphere in your home at anytime.
Preset for Convenience
Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights.
Easily Manage Your Life
Create regular schedules and countplans to turn on/off with the brightness you set. Sunrise and sunset modes allow the light to activate automatically according to your time zone.
Start a Lifestyle Powered by Your Voice
Works with Amazon Alexa and Google Assistant to free up your hands. Just say "Alexa, turn on the light" or "Hey Google, dim my bedroom lights."
Streamline Your Life with Remote Control
With L5350 and the Tapo app, you just need one tap on your smart phone, then everything is on. No matter how late you arrive home ,Tapo is always there. Welcome home!
Go on Vacation with Peace of Mind
Away Mode turns your lights on/off at random intervals to make it look like someone is home—deterring anyone with ill intent.
No Hub Required
Connect the L530 Light to your home Wi-Fi network, then you are all set. No need for extra hubs or other devices.
Energy Saving
Advanced technology allows Tapo L530 to use less energy than normal LED lights—only 8.7 W for 806 lm (60 W equivalent).
Tapo Ecosystem
The Tapo app puts total control in the palm of your hand. Tapo’s ever-growing ecosystem makes your home truly smart.
Product Description | Tapo L530B - LED light bulb - B22 - 8.7 W - 16 million colours - 2500-6500 K | Light Source Type | LED light bulb | Socket Type | B22 | Wattage | 8.7 W | Wattage Equivalent | 60 W | Energy Efficiency Class | F | Colour of Illumination | 16 million colours | Colour Temperature | 2500-6500 K | Luminous Power | 806 lumens | Beam Angle | 220 degree(s) | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Communications Technology | Wi-Fi | Voltage Required | AC 220 - 240 V | Frequency Required | 50/60 Hz |
Light Source | |
Socket Type | B22 |
Wattage | 8.7 W |
Energy Consumption per 1000h | 9 kWh |
Warm-Up Time | 1 sec |
Dimmable | Yes |
Switch Cycles | 15000 |
Features | Automatic colour changing mode, 1%-100% dimmable, Android compatible, iOS compatible, app-controlled, programmable usage modes, adjustable colour temperature, power on/off timer, away mode |
Power Requirements | |
Power Consumption Stand by | 0.14 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Not needed |
Compatible Application | Tapo app |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Compliant Standards | RoHS, ERP |
Dimensions & Weight | |
Diameter | 60 mm |
Length | 115 mm |
Weight | 74 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
