TP LINK AV200 200Mbps Mini Powerline Adapter Starter Kit
Customer rating
View reviews
TP-LINK's TL-PA211 powerline adapter takes advantage of your home's existing electrical wires to transfer data while simultaneously transferring traditional power.
That means, with no additional wiring required, users can simply plug the TL-PA211 into existing power sockets and instantly establish a networking infrastructure.
With high-speed data transfer rates of up to 200Mbps, users can enjoy HD video streaming, online gaming, VoIP or any other bandwidth intensive tasks for work or play.
Super Small Design
With its new ultra-compact housing design, TP-LINK's TL-PA211 is much smaller than most other 200Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it nearly blends completely in front of any power outlet.
Up to 200Mbps, 300 Meters
With advanced HomePlug AV technology, TL-PA211 provides users with stable, high-speed data transfer rates of up to 200Mbps on a line length of up to 300 meters.
Together with its built-in Qos and powerful AES encryption, the TL-PA211 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
Twin Pack Design
A PLC (powerline) connection is established by transmitting data through the electrical wires between two outlets, so it requires at least two PLC adapters plugged into those two outlets to complete the network.
With twin pack design, the starter kit is ideal for new users establishing their first PLC network or experienced users intent on expanding their networks.
Reduces Power Consumption Up to 65%
The TL-PA211, a new-generation Powerline Adapter, with its practical design and sophisticated Power-Saving Mode consumes less power when compared with existing Powerline Adapters.
When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce its energy consumption by up to 65%*.
*Actual data will vary because of the network conditions and environmental factors
Pair Button for Easy Network Security
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection, It's that simple!
Select any thumbnail below to view a larger image.
The following resources are available for the TP LINK AV200 200Mbps Mini Powerline Adapter Starter Kit
Write a review for the TP LINK AV200 200Mbps Mini Powerline Adapter Starter Kit here!
Just plug them in and switch on. Provided you can switch the second one on within 2 minutes of the first one, there are no problems.
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
