Click to visit BT.com
TP LINK 5-port 10/100 mini Desk Switch
TP LINK TP LINK 5-port 10/100 mini Desk Switch
Usually dispatched within 3 working days
Quicklinx: 77SBWS00
Mfr#: TL-SF1005D
£7.58
The TL-SF1005D Fast Ethernet Switch is designed for SOHO (Small Office/Home Office) or workgroup users. All 5 ports support auto MDI/MDIX, no need to worry about the cable type, simply plug and play. Moreover, with the innovative energy-efficient technology, the TL-SF1005D can save up to 70%* of the power consumption and 80% of the packaging material can be recycled, making it an eco-friendly solution for your business network.
High Performance TL-SF1005D Fast Ethernet Switch provides 5 10/100Mbps Auto-Negotiation RJ45 ports. All ports support Auto MDI/MDIX function, eliminating the need for crossover cables or Uplink ports..Featuring non-blocking switching architecture,TL-SF1005D forwards and filters packets at full wire-speed for maximum throughput. With 10K Jumbo frame, the performance of large files transfers is improved significantly. And IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode alleviate the traffic congestion and make TL-SF1005D work reliably. Easy to Use The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100 Mbps) and intelligently adjusts for compatibility and optimal performance.
-Innovative energy-efficient technology saves power up to 70% -Supports IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode -Non-blocking switching architecture that forwards and filters packets at full wire-speed for maximum throughput -Auto-MDI/MDIX eliminates the need for crossover cables -Supports MAC address auto-learning and auto-aging -Auto-negotiation ports provide smart integration between 10Mbps, 100Mbps and 1000Mbps hardware -Fanless design ensures quiet operation -Desktop or wall-mounting design -Plug and Play design simplifies installation
TP-LINK TL-SF1005D 5-Port 10/100Mbps Desktop Switch - switch - 5 ports - desktop
Switch - 5 ports
Enclosure Type
Desktop
Ports
5 x 10/100
MAC Address Table Size
1K entries
Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
( 50/60 Hz )
14 cm x 8.5 cm x 3 cm
Switch - 5 ports
Enclosure Type
Desktop
Ports
5 x 10/100
1K entries
Status Indicators
Link activity, power
5 x 10Base-T/100Base-TX - RJ-45
Power adapter - external
( 50/60 Hz )
14 cm
8.5 cm
3 cm
FCC
10 - 90%
feature value
Type Fast Ethernet
Ports 5
Data Transfer Rate 100Mbps
Brand TP LINK
Price Range Inc VAT 0 - 50
