BT.com
Wishlist
TP LINK 4 Port Router 1 x WAN 4 x LAN Cable/DSL Router IP QoS
Delivery
Standard Due date unavailable
With 4 LAN ports, TL-R460 Multifunctional Broadband Router is especially designed for small enterprise, office and SOHO (Small Office/Home Office) to access the Internet. It features strong functions, high performance, and easy configuration router. The TL-R460 provides many management functions, including system, DHCP server, virtual server, DMZ host, firewall, and static routing table, additionally, it features much more advanced functions, such as Parental Control, IEEE 802.1X Authentication, UPnP, DDNS, VPN Pass-through and System Log and so on.
The TL-R460 router provides flexible access control, limiting staff or children to browse selected sites. The TL-R460 router is also a smart helper. It connects to the Internet automatically on demand and disconnects when idle to save on network costs. It's easy to configure. Quick Setup Wizard is supported and friendly help pages are provided for every step also.
TP-LINK TL-R460 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet
Network / Transport Protocol
TCP/IP, L2TP, ICMP/IP, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, dynamic IP address assignment, DHCP support, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, URL filtering, parental control, IP address filtering, firmware upgradable, SNTP support, Quality of Service (QoS), virtual server support
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.1x
(50 Hz)
18.6 cm x 14.6 cm x 4.4 cm
Enclosure Type
Desktop
Wired
Routing Protocol
Static IP routing
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.1x, FCC
Status Indicators
Link activity, 100M device connected
WAN: 1 x RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
External power adapter
(50 Hz)
3.6 Watt
18.6 cm
14.6 cm
4.4 cm
10 - 90%
Scroll to top
