The TL-SG2424P provides 24 10/100/1000 Mbps ports that support 802.3at/af-compliant PoE, with a total PoE power supply up to 180 W, powerful and flexible enough for users to deploy wireless access points or IP-based network surveillance cameras. The switch also comes equipped with 4 combo SFP slots, expanding your network flexibly. In addition, it provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features. With all these advanced features, the Gigabit Smart PoE switch is an ideal choice for small and medium business networking.
TL-SG2424P has useful security features. The storm control feature protects against broadcast, multicast and unknown unicast storm. Quality of Service provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with CLI, SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch and gigabit capability, TP-LINK Gigabit Smart PoE switch TL-SG2424P provides you the ideal access-edge solution.
Product Description | TP-Link TL-SG2424P - switch - 24 ports - Managed - rack-mountable | Device Type | Switch - 24 ports - Managed | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 24 x 10/100/1000 (PoE+) + 4 x combo SFP | Power Over Ethernet (PoE) | PoE+ | Performance | Backplane speed: 48 Gbps , Forwarding performance: 35.7 Mpps | Capacity | Active VLANs: 512 | MAC Address Table Size | 8K entries | Jumbo Frame Support | 10240 bytes | Routing Protocol | IGMPv2, IGMP, IGMPv3 | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI | Features | Flow control, DHCP support, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, Link Aggregation Control Protocol (LACP), Port Security, Strict Priority Queuing (SPQ), loop prevention, Class of Service (CoS) | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at | Power | AC 120/230 V (50 - 60 Hz) | Dimensions (WxDxH) | 44 cm x 33 cm x 4.4 cm | System Requirements | UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 7, Microsoft Windows NT / 2000 / XP, Microsoft Windows Vista, Windows 8 |
General | |
Encryption Algorithm | SSL, TLS 1.0, SSL 2.0 |
Authentication Method | Secure Shell (SSH), Secure Shell v.2 (SSH2) |
Status Indicators | Power, 100M device connected, system, 1000M device connected, PoE |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 PoE+ , 4 x 1000Base-T SFP |
Power | |
Power Device | Internal power supply |
Power Provided | 180 Watt |
Voltage Required | AC 120/230 V (50 - 60 Hz) |
Miscellaneous | |
Included Accessories | Rubber feet |
Rack Mounting Kit | Included |
Compliant Standards | RoHS, FCC Part 15 A |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 7, Microsoft Windows NT / 2000 / XP, Microsoft Windows Vista, Windows 8 |
Dimensions & Weight | |
Width | 44 cm |
Depth | 33 cm |
Height | 4.4 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
