Wishlist updated!
Polaroid Now+ Gen 2 - White
You have added Polaroid Now+ Gen 2 - White to your Wishlist
TP LINK 16-Port 10/100Mbps PoE+ Switch
£138.22
Delivery:
Standard: 1-3 working days
Key features
  • 16 PoE+ 10/100Mbps RJ45 ports, 2 Gigabit RJ45 ports and 2 combo Gigabit SFP slots
  • Up to 250m data and power transmission under extend mode specially designed for surveillance system
  • Priority mode for port1-8 to guarantees the quality of sensitive applications like video monitor
  • High PoE power budget with up to 30W for each PoE port and 192W for all PoE ports
  • Easy to use, with no configuration and installation needed
  • Type: Fast Ethernet
  • Ports: 16, 16-28
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: PoE+
Product codes
chevron icon
chevron icon
TP-Link's new TL-SL1218MP PoE switch with all 16 ports supporting the PoE+ standard provides a simple way to expand the wired network while transferring power over the same Ethernet cable at the same time. With a total power budget of 192W, up to 30W per port, TL-SL1218MP can power more high-powered devices such as Access Points, IP Cameras, IP Phones and so on. Moreover, with innovative Extend Mode, devices can get PoE power supply and data transmission from 250m's distance. Priority mode ensures high priority for Port 1-8, which guarantees the quality of sensitive applications.
chevron icon
Product Description TP-Link TL-SL1218MP - switch - 16 ports - unmanaged - rack-mountable
Device Type Switch - 16 ports - unmanaged
Enclosure Type Rack-mountable
Subtype Fast Ethernet
Ports 16 x 10/100 (PoE+) + 2 x 10/100/1000 + 2 x combo Gigabit SFP
PoE Budget 192 W
Performance Switching capacity: 7.2 Gbps , Packet forwarding rate: 5.36 Mpps
MAC Address Table Size 8K entries
Jumbo Frame Support 10KB
Features Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 18 cm x 4.4 cm
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£138.22
