Designed for ease of use, the latest Toshiba USB Flash drives feature a stylish and compact redesigned case incorporating an innovative slide mechanism that allows for single-handed opening.
USB 2.0 Standard
The USB 2.0 standard A Type has a size of 12mm width and a height of 4.5mm. Suitable in all USB 2.0 ports which is standard in every PC. Data transmission is possible in both directions.
Hot plug and unplug
Devices can be connected and detected during operation. Just plug and play and transfer your favorite music and images.
Your Data is Safe with Toshiba's Original Security Software
The series supports application software that allows protection of a particular block with a password lock so that data and files stored in that block cannot be accessed without the password.
One of the Lowest Power Consumption in the Industry
Low power consumption is achieved thanks to Toshiba's original technology, such as multi-layering of high-speed NAND flash memory and a dedicated low-power-consumption ASIC controller. As a result, power consumption of notebook PCs is minimized even when using a USB flash memory.
5 Year Warranty
These Flash drives are covered by a five year warranty from the date of purchase.
Product Description | Toshiba TransMemory - USB flash drive - 16 GB | Product Type | USB flash drive | Interface Type | USB 2.0 | Storage Capacity | 16 GB | OS Required | Microsoft Windows 2000/XP/Vista/7, Apple MacOS X 10.0.2 or later | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 17 MB/s |
Write Rate | Up to 7 MB/s |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 21.4 mm |
Depth | 51.4 mm |
Height | 8.4 mm |
Weight | 8 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 20 - 95% (non-condensing) |
