Every professional needs a laptop that will help speed through business, not slow it down. That's why the 39.6 cm (15.6") Satellite Pro A50 from Toshiba offers nothing less than multi-tasking at its best. The next generation in an established line of professional Satellite Pro laptops, it uses a high-capacity processor to power through the busiest or most varied of workloads. And with a durable design plus security features built in, you can rely on it to protect your data too.
Product Description | Dynabook Toshiba Satellite Pro A50-C-1GC - 15.6" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 8 GB DDR3L (1 x 8 GB) | Storage | 256 GB SSD | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 520 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 4-cell - up to 8 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Graphite black, black (keyboard) | Dimensions (WxDxH) | 37.9 cm x 25.8 cm x 2.395 cm | Weight | 2.1 kg | Localisation | Region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | EMEA warranty - 1 year - carry-in |
General | |
Operating System | Windows 10 Home 64-bit Edition (preloaded) |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD SATA |
Optical Drive | DVD±RW (±R DL) / DVD-RAM |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HighBrightness, anti-reflective |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - Full HD |
Resolution | 2 Megapixel |
Sound | Stereo speakers, stereo microphone |
Compliant Standards | DTS Sound |
Input | |
Type | Keyboard, touchpad |
Features | Palm Rejection Technology, multi-touch touchpad |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 8260 |
Network Interface | Gigabit Ethernet |
Compliant Standards | Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell Lithium Ion |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 19 V, 2.37 A |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , LAN , HDMI , Headphone/microphone combo jack , VGA , 2 x USB 2.0 |
Memory Card Reader | Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card) |
Software | |
Software Included | Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription) |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, 3D Accelerator |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2.1 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | EMEA warranty - 1 year - carry-in |
