Click to visit BT.com
Toshiba CAMILEO S30 BURGUNDY RED
Toshiba Toshiba CAMILEO S30 BURGUNDY RED
Quicklinx: 7BK1WS00
Mfr#: PX1744E-1CAM
Toshiba Camileo S30 comes with Full HD resolution and is designed to be as user-friendly as possible: it features a large touch sensitive screen that displays an easy-to-use graphical user interface. The Camileo S30 is equipped with an 8-megapixel CMOS sensor.
Reach out with your 10x digital zoom and control recordings on the large 3-inch touchscreen LCD monitor. Create multi-scene video files thanks to the pause feature button! Save the best moments of your life with your Camileo S30 camcorder.
Toshiba CAMILEO S30 - camcorder - flash card
Camcorder - 1080p - widescreen
Media Type
Flash card
Memory Card Slot
SD card
Internal Storage
128 MB flash
Sensor Resolution
8.0 Mpix
Effective Sensor Resolution
Photo: 8.0 Mpix
Lens System
Lens - 5.7 mm - f/2.5
Focus Adjustment
Focus free
Min Focus Range
1.2 m
Digital Zoom
16 x
Image Stabiliser
Electronic
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery ( included )
AV Interfaces
Composite video/audio, HDMI
Burgundy red
1.9 cm x 5.9 cm x 10.6 cm
118 g
Camcorder - 1080p
Enclosure Colour
Burgundy red
Camcorder Sensor Resolution
8.0 Mpix
Effective Photo Resolution
8.0 Mpix
Camcorder Interpolated Photo Resolution
16.0 Mpix
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CMOS
Digital Zoom
16 x
Image Stabiliser
Electronic
Digital Video Format
MPEG-4
Image Recording Format
JPEG
AV Interfaces
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic, presets
White Balance Presets
Fluorescent, tungsten light, daylight
Lens System
Focus Adjustment
Focus free
Min Focus Range
1.2 m
Macro Focus Range
21cm
Additional Features
Self Timer Delay
10 sec
Built-in Light
Additional Features
USB 2.0 compatibility, touch-screen control, auto power save, YouTube capture mode
Display
3" LCD display
Display Features
Rotating
Connector Type
1 x USB , 1 x composite video/audio output , 1 x HDMI
Memory Card Slot
SD card
Software
Software
Drivers & Utilities, ArcSoft MediaConverter, ArcSoft MediaImpression, Toshiba CAMILEO Uploader, MAGIX Video deluxe (trial)
System Requirements for PC Connection
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista
Peripheral Devices
USB port, CD-ROM Drive
System Requirements Details
Windows XP/Vista/7 - Pentium 4 - 2.4 GHz - 512 MB - 700 MB
Cleaning cloth, hand strap, tripod, power adapter, USB cable, HDMI cable, video cable
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Internal Storage
128 MB flash
Included Memory Card
128 MB
Image Storage
JPEG 4608 x 3456 , JPEG 3264 x 2448 , JPEG 2048 x 1536
Video Capture
MPEG-4 - 1920 x 1080 - 30 fps , MPEG-4 - 1280 x 720 - 30 fps , MPEG-4 - 1280 x 720 - 60 fps , MPEG-4 - 640 x 480 - 30 fps
1.9 cm
5.9 cm
10.6 cm
118 g
