Click to visit BT.com
Toshiba AC Adapter 19v DC
Toshiba Toshiba AC Adapter 19v DC
2 In stock
Quicklinx: 69H7WS00
Mfr#: PA3715E-1AC3
£30.91
Universal AC adapter is designed to power your notebook through your home or office electric socket. Toshiba's universal AC adapters can be used anywhere in the world with the appropriate AC plug adapter.
Toshiba power adapter - 75 Watt
Power adapter - external
12.7 cm x 3.1 cm x 5.1 cm
310 g
Input Voltage
AC 100-240 V
Output Voltage
19 V
Power Capacity
75 Watt
Output Connector(s)
1 x power DC jack
Portégé M800, R500, R500 3G-11, R500 3G-121; Satellite A500, A500/02, A660, A665, C650, C650D, C660, L550, L630, L650, L730, L750, L770, L770D, P750, P750D, P770, P770D, T110, T130, T130D, U300, U400; Satellite Pro L350, L450, L500, L550, L550D, L670, T130, U300, U400; Tecra R840, R850
12.7 cm
3.1 cm
5.1 cm
310 g
Enclosure Colour
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Output Voltage
19 V
1 x power DC jack
Max Electric Current
3.95 A
Power Capacity
75 Watt
No power cord is included
TUV GS, PCT, CCC, cULus
Toshiba Satellite A665-S5173, A665-S5183X, A665-SP6011M, C650-00P, C650D-005, C660-162, C660-19T, C660-1KG, C660-1ME, C660-1MF, C660-1MG, C660-1MK, C660-1NF, C660-1NW, C660-1RK, C660-1T9, C660-1TM, C660-1U0, C660-1U6, C660-1WM, C660-1WN, C660-1WV, C660-1WW, C660-1WX, C660-1WZ, C660-1X0, C660-1X1, C660-1X2, C660-1X4, C660-1X5, C660-1X6, C660-1X7, C660-1X9, C660-1XT, C660-1ZU, C660-21J, C660-21K, C660-21W, C660-21Z, C660-225, C660-226, C660-22C, C660-22Q, C660-22W, C660-23K, C660-246, C660-249, C660-24C, C660-258, C660-25U, C660-264, C660-26G, C660-26X, C660-28D, C660-28R, C660-28T, C660-28V, C660-2CR, C660-2D7, C660-2DL, C660-2DV, C660-2E1, C660-2E2, C660-2E3, C660-2EL, C660-2F2, C660-2FD, C660-2FE, C660-2G6, L650-10L, L730, L730-10X, L730-117, L750, L750-070, L750-10N, L750-114, L750-12U, L750-12Z, L750-148, L750-16J, L750-16L, L750-16V, L750-16W, L750-16X, L750-16Z, L750-170, L750-171, L750-176, L750-17D, L750-17P, L750-18R, L750-1DH, L750-1DJ, L750-1DK, L750-1DL, L750-1DM, L750-1DQ, L750-1DR, L750-1DU, L750-1DV, L750-1DW, L750-1DX, L750-1E5, L750-1E8, L750-1E9, L750-1EK, L750-1EZ, L750-1HR, L750-1KU, L750-1LC, L750-1RP, L770, L770-119, L770-11U, L770D-10H, P750, P750-10E, P750-11H, P750-121, P750-12U, P750-133, P750-13F, P750-13G, P750-13L, P750-13M, P750-13N, P750D, P770, P770-115, P770-116, P770-117, P770-11G, P770-11M, P770D , Toshiba Satellite Pro L670-EZ1715D , Toshiba Tecra R840-002, R840-003, R840-008, R840-009, R840-01J, R840-020, R840-021, R840-02X, R840-110, R840-12K, R840-13T, R840-146, R840-14F, R840-14T, R840-15J, R840-16W, R840-S8412, R840-S8422, R850-015, R850-017, R850-01D, R850-01F, R850-021, R850-02Y, R850-030, R850-034, R850-114, R850-146, R850-147, R850-14V, R850-150, R850-151, R850-154, R850-155, R850-173, R850-175, R850-176, R850-17C, R850-17H, R850-17L, R850-182, R850-18E, R850-18H, R850-19J, R850-1C3, R850-1C7, R850-1D7, R850-1D8, R850-S8512, R850-S8522, R850-S8532, R850-S8552, R850-SP5171M
feature value
Type Power Adapters
Brand Toshiba
Stock Status In Stock
Price Range Inc VAT 0 - 50
