Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
Toshiba 500GB Stor.E Basics USB 3.0 2.5" Portable Hard Drive Black
Quicklinx: 885SWS00
Mfr#: HDTB105EK3AA
Quickly transfer files with SuperSpeed USB 3.0 and store up to 500 GB of data on STOR. E BASICS external drives. Easy to use and backward compatible with USB 2.0, STOR. E BASICS external drives are ready to use with no software installation required.
The Toshiba STOR.E Basics 2.5 Inch 500GB external hard drive makes super speed storage simple. Receive high speed storage via the USB 3.0 port, allowing you to store your data with super speed. Enjoy high capacity storage of up to 500GB in a conveniently compact casing.
  • Interface type USB 3.0 (USB 2.0 compatible)
  • Interface Transfer rate max. 5.0 Gbps
  • On-bus power max. 900 mA
  • Dimensions (mm) 118.9 (L) x 79 (W) x 13.5 (H) mm
Box content
  • 500GB STOR.E Basics
  • USB 3.0 cable ("A" to Micro "B")
  • Quick Start Guide
  • Warranty Leaflet
  • pre-installed User Manual
Toshiba StorE BASICS - hard drive - 500 GB - USB 3.0
Hard drive - external ( portable )
500 GB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Ramp Load
Power Source
USB bus
Enclosure Colour
Matte black
7.9 cm x 11.9 cm x 1.4 cm
150 g
Toshiba LX830; NB510; NB520; Portégé R830, R930, Z830, Z930; Qosmio F750, X770, X870; Satellite C660, C670, C850, C850D, C855, C855D, C870, C870D, C875, C875D, L730, L735, L750, L750D, L755, L755D, L775, L775D, L830, L850, L850D, L855, L855D, L870, L870D, L875, L875D, L950D, L955, L955D, P750, P770, P845T, P850, P855, P870, P875, R830, R930, S70, U840, U840W, U920t, U940, Z830, Z930; Satellite Pro C660, C850, L770, L830, L850, L870; Tecra A11, R840, R940, R950
500 GB
2.5"
USB 3.0
Ramp Load
7.9 cm
11.9 cm
1.4 cm
150 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Microsoft Windows 7
1 x USB 3.0 cable - external
Plug and Play
Enclosure Colour
Matte black
Toshiba LX830-11G , Toshiba Portégé R930-14X, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV, Z930-13M, Z930-14D, Z930-153 , Toshiba Qosmio X870-140, X870-142, X870-15K , Toshiba Satellite C850-1F2, C850-1GL, C850-1JV, C850-1JZ, C850-1KM, C850-1KR, C850-1LH, C850-1LW, C850-1LX, C850-1M8, C850-1MC, C850D-115, C850D-12L, C850D-12V, C855-1VX, C855-1WZ, C855-1XC, C855-1XD, C855-1XE, C855-20N, C855-20P, C855-21V, C855-21W, C855-253, C855-27L, C855-28U, C855-29L, C855-29M, C855-29N, C855-2EE, C855-2EF, C855-2EJ, C855-2ET, C855-2EU, C855-2EZ, C855-2F0, C855-2F1, C855-2F2, C855-2F3, C855-2F7, C855-2F8, C855-2F9, C855-2FC, C855-2FN, C855-2FP, C855-2FQ, C855D-150, C855D-15U, C855D-15W, C855D-15Z, C870-18C, C870-18M, C870-19H, C870-1CH, C870-1D2, C870-1EW, C870-1F3, C870-1FE, C870-1GF, C870-1GW, C870-1GZ, C870-1H0, C870-1H2, C870-1HE, C870D-119, C870D-11E, C870D-11F, C870D-11P, C870D-11T, C870D-11V, C870D-11X, C870D-11Z, C870D-120, C875-114, C875-150, L830-13J, L830-13K, L830-14G, L830-15G, L830-15H, L830-15J, L830-15L, L830-160, L830-164, L850-1K1, L850-1KG, L850-1Q2, L850-1TE, L850-1V0, L850-1V1, L850D-12T, L855-14K, L855-15L, L855-15U, L855-179, L855-17Q, L855-17R, L855D-10J, L870-182, L870-18K, L870-18Q, L870-18V, L870D-10N, L870D-10V, L870D-10W, L875-12V, L875-132, L950D-100, L955-108, L955-10F, L955-10J, L955D-104, L955D-107, L955D-10F, P845t-10G, P845t-10J, P850-32M, P850-32Z, P855-33X, P855-34P, R930-1CV, S70-B-10F, U920t-10F, U920t-117, U920t-11C, U940-11N , Toshiba Satellite Pro C850-19G, C850-1D4, C850-1DC, C850-1DE, C850-1FR, C850-1GR, C850-1H8, C850-1HD, C850-1HE, C850-1K1, C850-1K2, C850-1K3, C850-1K4, C850-1LV, C850-1M7, L830-14F, L830-15W, L850-1P7, L850-1P8, L850-1UJ, L850-1UK, L870-16Z, L870-17X, L870-18G, L870-18L, L870-18R , Toshiba Tecra R940-1GQ, R940-1JF, R940-1JG, R940-1JH, R940-1L0, R940-1L1, R950-176, R950-1EJ, R950-1EK, R950-1EL, R950-1EM, R950-1EN, R950-1JH, R950-1JJ
Resources
The following resources are available for the Toshiba 500GB Stor.E Basics USB 3.0 2.5" Portable Hard Drive Black
