BT.com
Wishlist
Toshiba 1TB Canvio Basics USB 3.0 2.5" Portable Hard Drive
Toshiba 1TB Canvio Basics USB 3.0...
Limited Time Offer
£47.98
Limited Time Offer
Our best-selling 1TB Portable Drive!
More than 50 in stock
£47.98
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Toshiba's Canvio Basics for the PC requires only a single step to start saving and transporting important files, plug it in. With no software necessary to install, the Canvio Basics portable hard drive offers a hassle-free, high capacity storage solution right out of the box.
A sleek solution with plenty of storage capacity for the growing amount of digital content, from photos and videos to music and documents, the Canvio Basics offers an intelligent combination of data protection, portability, and simplicity. The one plug ease-of-use is complemented by the drive's stylish design, courtesy of a glossy finish and soft, rounded edges. Despite its light weight design and diminutive size, the Canvio Basics can add peace of mind by keeping files safe with its internal shock sensor and Ramp Loading technology.
Beyond its technical capabilities, the practicality of the Canvio Basics portable hard drive is evident in the drive's pocket-sized form factor which not only makes it easy to carry but also conforms to Toshiba's environmental efforts to reduce materials used in production. In addition, the Canvio Basics' packaging is made from 100 percent recyclable materials.
Toshiba Canvio Basics - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
Matte black
7.9 cm x 11.9 cm x 1.5 cm
230 g
1 TB
2.5"
USB 3.0
7.9 cm
11.9 cm
1.5 cm
230 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Microsoft Windows 7 / Windows 8, Windows 8.1
System Requirements Details
750 MHz - RAM 256 MB
1 x USB 3.0 cable - external
Enclosure Colour
Matte black
Other bundles
Toshiba 1TB Canvio Basics USB 3.0 2.5" Portable Hard...
£47.98
Half Price Hard Drive Case with portable hard drives
Save £4.99
£52.97
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Five Star Product
Reviewed by Anonymous on 03/12/2014
Excellent external hard drive. Purchased to back-up a lot of photographs from my ageing computer. Plugged it in and it was recognised straight away by internet explorer, just copied and pasted the photos from the computer to the hard drive. Took some time as the computer only has USB 2.0 and not 3.0 which would have sped up the process, the limitation being the computer no the drive - the drive is super-fast!
4* They do work with Mac's
Reviewed by Tom on 07/03/2016
I have to disagree with the review from 18th Feb 2016.
The disks come formatted as NTFS, Mac's can read (but not write) with this format.
All you need to do is use Disk Utility to reformat / partition the drive as Mac OS Journalled.
It will now work perfectly with an Apple computer.
Scroll to top
