Synology DiskStation DS3615xs provides a premium-performance NAS solution for large scale businesses that require an efficient way to centralize data protection, simplify data management, deploy virtualization solutions, and rapidly expand storage capacity with minimal time spent on setup and maintenance.
Product Description | Synology Disk Station DS3615xs - NAS server - 48 TB - TAA Compliant | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 48 TB | Max Supported Capacity | 72 TB | Installed Devices / Modules Qty | 12 (installed) / 12 (max) | Dimensions (WxDxH) | 30 cm x 34 cm x 27 cm | Weight | 9.8 kg () | Processor | 1 x Intel Core i3 4130 3.4 GHz (Dual-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare | Hard Drive | 12 x 4 TB SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | IP Cameras Supported | 75 | RAM | 4 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | TAA Compliant | Yes | Manufacturer Warranty | 5-year warranty |
General | |
Width | 30 cm |
Depth | 34 cm |
Height | 27 cm |
Processor / Memory | |
Processors Installed | 1 x Intel Core i3 4130 3.4 GHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 4 GB (installed) / 32 GB (supported) - DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare |
Hard Drive | |
Type | HDD - hot-swap - 3.5" |
Capacity | 12 x 4 TB |
Spindle Speed | 7200 rpm |
Buffer Size | 64 MB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | L2TP, iSCSI, LPR/LPD, SMTP, FTP, POP3, IMAP |
Remote Management Protocol | Telnet, HTTPS, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, LDAP support, wake on LAN (WOL), Syslog support, print server, download client, Access Control List (ACL) support, RADIUS support, iTunes server, BitTorrent Client, e-mail server, bandwidth control, surveillance station, DNS server, eMule client, VPN Server |
Encryption Algorithm | SSL, TLS |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 1 (total) / 1 (free) x PCI Express x8 |
Interfaces | 2 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 1 x serial (management) - DB-9 |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), built-in 2 cooling fans, Google Cloud Print |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, RoHS, BSMI Class B |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 500 Watt |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Sound Emission | 27.4 dBA |
