Swann Communications DVR8-2600 8 Channel Video Surveillance System
8 Channel Digital Video Recorder with pre-installed 500GB HDD / H.264 latest recording technology / Web and Smartphone connection for remote viewing / Transfer incidents to USB flash drive / 4 x CCD cameras, add an additional 4 cameras / VGA connection.
apable of monitoring and recording images from the 8 channels simultaneously, the Swann DVR8-2600 digital video recorder offers you state of the art, professional monitoring capabilities in an easy to install, easy to setup and easy to use package. The included four professional grade PRO-580 CCD cameras will provide crystal clear video direct to the DVR, add an additional 4 cameras for added protection.
You can view all four PRO-580 cameras at once on your television or on a PC monitor using the high resolution VGA output. You can also securely access your system from practically anywhere in the world from almost any computer connected to the internet, or even from your 3G enabled Smartphones including iPhone, iPad, Blackberry, Android, Windows Mobile 6, Symbian and more*. Simply download an app for your phone system from Swannview page.
You're in total control of the DVR's recording modes - easily select your preferred resolution, frame rate and the amount of video compression. You can record from four cameras for up to 60 days+ continuously onto the massive 500 gigabyte hard drive.
You can also save time and hard drive space using the DVR8-2600's advanced motion detection recording. Even better, the time and date are integrated into your video files, allowing you to find, trim and transfer events to a USB flash drive for easy storage and retrieval. You can also be sent email alerts when activity is detected for peace of mind, all the time.
The Swann DVR8-2600 professional, affordable, simple and powerful. It really is advanced security made easy.
