Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
StarTech.com USB to VGA Multi Monitor External Video Adapter
Quicklinx: 660DWS00
Mfr#: USB2VGAE2
Express delivery Order within the next 9 hours for delivery tomorrow
13 in stock
£35.20
The USB2VGAE2 USB to VGA external video adapter is the perfect multi-monitor VGA solution for office applications and Internet browsing.
The USB video adapter features a small form factor and enables a USB 2.0 port to be used with a VGA port. A cost-saving multi-monitor or dual display option that can be used as an external graphics card for either laptop or desktop applications.
The USB video adapter can be used with up to four additional (five total) USB2VGAE2 USB video adapters, creating multiple VGA connections that can be used to further extend or mirror the desktop shown on the existing display - all without having to open the computer case to add extra video cards.
StarTech.com USB to VGA Multi Monitor External Video Adapter external video adapter - 16 MB - grey
External video adapter
Bus Type
USB 2.0
16 MB - SDRAM
Max Resolution
1680 x 1050
VGA
4.2 cm x 7.5 cm x 5 cm
Enclosure Colour
Grey
2 years warranty
Bus Type
USB 2.0
Max Resolution
1680 x 1050
VGA
Size
16 MB
SDRAM
Video Output
Supported Display Graphics
XGA (1024x768), SVGA (800x600), SXGA (1280x1024), SXGA+ (1400x1050), UXGA (1600x1200), 1152x864, 1280x960, 1280x800, 1440x900, 1280x768, 1680x1050
Colours Max Resolution (external)
32-bit colour
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Additional Requirements
USB 2.0 port
1 x USB cable - 45.72 cm
Software Included
Drivers & Utilities
Plug and Play, FCC, RoHS
4.2 cm
7.5 cm
5 cm
120 g
Enclosure Colour
Grey
2 years warranty
Service & Support Details
660D StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £12.85
660D StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £6.07
660D StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £9.81
Price Range Inc VAT: 0 - 50
