Click to visit BT.com
StarTech.com USB To SATA IDE External Docking Station
StarTech.com StarTech.com USB To SATA IDE External Docking Station
5 in stock
Quicklinx: 6CYHWS00
Mfr#: UNIDOCK2U
£34.99
Connect both an IDE and SATA hard drive to a computer through USB 2.0.
The UNIDOCK2U HDD Docking Station delivers full, instant access to any 2.5" and/or 3.5" IDE or SATA hard drive without having to mount the drive in a computer, or install it in an external enclosure. Large capacity drives (tested with up to 4TB) can be used to greatly enhance your computer's storage/backup capabilities.
Connected to the host computer through a single USB 2.0 connection, both an IDE hard drive and a SATA hard drive (SATA, SATA II, SATA III) can be connected to the HDD dock simultaneously - a convenient solution for migrating data from an IDE drive to a SATA drive or vice versa, or simply harnessing fast and simple access to the contents on both hard drives.
The hard drive docking station provides the ideal solution for any laptop or desktop application, with support for plug and play hard drive installation on most operating systems to ensure easy hard drive swapping and convenient access to valuable data.
StarTech.com USB to SATA IDE Hard Drive Docking Station 2.5/3.5in HDD Dock - storage controller - IDE / SATA-300 - USB 2.0
Storage controller - external
Interface Type
Hi-Speed USB
9.3 cm x 14.5 cm x 6.5 cm
413 g
Enclosure Colour
North America, United Kingdom, Europe
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
Controller Interface Type
IDE / Serial ATA-300
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Power Source
Included AC adapter
AC 120/230 V
Linux, Apple MacOS 9.2 or later, Microsoft Windows 7, Microsoft Windows Vista / 2000 / XP
2 years warranty
2.5", 3.5"
Interface Type
Hi-Speed USB
9.3 cm
14.5 cm
6.5 cm
413 g
Enclosure Colour
Storage Controller
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Expansion Bays
1 x storage - IDE - 40 PIN IDC , 1 x storage - Serial ATA-300 - 7 pin Serial ATA
1 x Hi-Speed USB - 4 PIN USB Type B
1 x USB cable - external , 1 x IDE adapter - external - 12 cm , 1 x IDE cable - external
Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
FCC, RoHS
Power Source
Included AC adapter
Power adapter
AC 120/230 V
2 years warranty
Service & Support Details
feature value
Type Dock
Brand StarTech.com
Stock Status In Stock
Price Range Inc VAT 0 - 50
