Click to visit BT.com
StarTech.com USB Media Memory Card Reader
StarTech.com StarTech.com USB Media Memory Card Reader
1 in stock
Quicklinx: 5D3BWS00
Mfr#: FCREADMICRO
£8.72
Add a compact external memory card reader to any computer with a USB port. An ideal laptop or desktop accessory, this pocket-sized memory card reader connects to a computer through USB to support the most popular memory card formats, providing an all-in-one flash memory solution.
This multi-format memory card reader supports Memory Stick, MS Pro, MS Duo, MS Pro Duo, MS MG, MS Micro (M2), Micro SD, Mini SD, RS MMC/MMC 4.0, Ultra II SD, Extreme SD, Extreme II SD, T-Flash (no adapter required) and more, as well as high capacity cards such as SDHC and SDXC. Plus, this card reader is backward compatible with older card formats such as SD, to ensure you can access and write to your memory card without any hassles.
Image gallery
Select any thumbnail below to view a larger image.
StarTech.com USB Multi Media Memory Card Reader Adapter - card reader - Hi-Speed USB
Card reader ( external ) - Hi-Speed USB
Enclosure Colour
Supported Flash Memory
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, TransFlash, microSD, Memory Stick Micro (M2)
Microsoft Windows 98SE/2000/ME/XP, Apple MacOS 9.x or later, Microsoft Windows Vista
2 years warranty
Enclosure Colour
193 mm
10 mm
41 g
1 x Hi-Speed USB - 4 PIN USB Type A
FCC
2 years warranty
Service & Support Details
Accessories
1-1 products displayed out of 1
  product description   In stock inc VAT qty
  StarTech.com Mini 4 Port USB 2.0 Hub StarTech.com Mini 4 Port USB 2.0 Hub
quicklinx: 5FRCWS00 | Mfr#: ST4200MINI
Usually shipped in 3 days £9.99
feature value
Supported Formats Memory Stick
Supported Formats Memory Stick Duo
Supported Formats Memory Stick Micro (M2)
Supported Formats Memory Stick PRO
Supported Formats Memory Stick PRO Duo
Supported Formats microSD
Supported Formats miniSD
Supported Formats MultiMediaCard
Supported Formats RS-MMC
Supported Formats SD Memory Card
Supported Formats TransFlash
Interface Hi-Speed USB
Brand StarTech.com
Stock Status In Stock
Price Range Inc VAT 0 - 50
