Click to visit BT.com
StarTech.com RJ45 to Fiber Media Converter
StarTech.com StarTech.com RJ45 to Fiber Media Converter
Quicklinx: 6BDBWS00
Mfr#: MCM110SC2GB
Convert and extend a 10/100 Mbps Ethernet connection up to 2 km over Multi Mode SC fiber.
The MCM110SC2GB 10/100 Multi Mode Fiber Ethernet Media Converter SC 2 km creates an economical, cost-effective Ethernet-fiber link, transparently converting to/from 10Base-T or 100Base-Tx Ethernet signals and 100Base-Fx optical signals to extend an Ethernet network connection over an SC terminated multimode fiber backbone.
The converter supports a maximum multimode fiber optic cable distance of 2 kilometers (1.2 miles), providing a simple solution for connecting 10Base-T/100Base-Tx Ethernet networks to remote locations using SC-terminated multimode fiber, while delivering solid network performance and scalability.
This versatile GbE Ethernet to Fiber converter is compatible with most 3COM, Cisco, Lucent and Nortel networks and fully complies with applicable IEEE 802.3 standards.
StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km - media converter
Media converter - RJ-45 / SC multi-mode
Enclosure Type
External
7.3 cm x 9.7 cm x 2.3 cm
90 g
United Kingdom
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
Ethernet, Fast Ethernet
Max Transfer Distance
2 km
Flow control, MDI/MDI-X switch, auto-negotiation, half duplex mode, full duplex mode, Link Fault Pass Through function (LFP), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q , CE, FCC, RoHS
AC 230V
2 years warranty
Media converter
Enclosure Type
External
7.3 cm
9.7 cm
2.3 cm
90 g
Enclosure Colour
United Kingdom
Wired
Cabling Type
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Status Indicators
Link activity, port transmission speed, port duplex mode, power
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x network - Ethernet 100Base-FX - SC multi-mode female x 2
CE, FCC, RoHS
Power adapter - external
AC 230V
2 years warranty
Service & Support Details
50 °C
0 - 90%
