StarTech.com Fiber Ethernet Media Converter
This 10/100Base to 100Base-FX (ST) Multimode Fiber Ethernet media converter supports a maximum fiber cable distance of 2km, ensuring a highly reliable signal for ideal network connectivity and performance. The fiber converter features Power over Ethernet support that allows the converter to draw power from a PoE network, delivering the freedom to use the converter in environments and scenarios where additional standard power options are unavailable. Rather than paying for expensive installations of power wire (at drop points that may have them), running PoE requires only standard network cable (e.g. Cat5e cable), eliminating cost and hassle.
Select any thumbnail below to view a larger image.
