Click to visit BT.com
StarTech.com External HDD Dock / Hard Drive
StarTech.com StarTech.com External HDD Dock / Hard Drive
Usually dispatched within 3 working days
Quicklinx: 5KMFWS00
Mfr#: SATDOCKU2GB
£20.98 inc VAT
This external hard drive dock adapter functions as a SATA HDD docking station - providing full, instant access to any 2.5in or 3.5in SATA (SATA, SATA II, SATA III) hard drive or solid state drive - without having to mount the hard drive in a computer or install it in an enclosure!
Simply connect the hard drive dock to a host computer through USB 2.0, then insert a SATA hard drive into the dock whenever needed. To uninstall or swap the hard drive, just remove it from the dock!
The USB to SATA External HDD Dock Adapter supports plug and play hard drive installation on most operating systems, and offers data transfer speeds of up to 480Mbps - providing a convenient alternative to external hard drive enclosures and saving the time needed to prepare the drive for conventional installation. Double the value of this hard drive docking station, using a SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
StarTech.com USB to SATA External HDD Dock for 2.5 or 3.5in Hard Drive - storage controller - SATA-300 - Hi-Speed USB
Storage controller - external
Interface Type
Hi-Speed USB
9.1 cm x 14 cm x 5.5 cm
220 g
Enclosure Colour
United Kingdom
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
Controller Interface Type
Serial ATA-300
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Power Source
Included AC adapter
Red Hat Linux 9, Microsoft Windows 98SE/2000/ME/XP, Apple MacOS X 10.3.9 or later, Red Hat Fedora Core 4, Microsoft Windows Vista, Red Hat Fedora Core 5, Microsoft Windows Vista (64-bit versions), Microsoft Windows 2003
2 years warranty
2.5", 3.5"
Interface Type
Hi-Speed USB
9.1 cm
14 cm
5.5 cm
220 g
Enclosure Colour
United Kingdom
Storage Controller
Serial ATA-300
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Expansion Bays
1 x storage - Serial ATA-300 - 15 pin Serial ATA power , 1 x storage - Serial ATA-300 - 7 pin Serial ATA
1 x Hi-Speed USB - 4 PIN USB Type B
1 x USB cable - external
Plug and Play, CE, UL, FCC, RoHS
Power Source
Included AC adapter
Power adapter
2 years warranty
Service & Support Details
Accessories
1-1 products displayed out of 1
  product description   In stock inc VAT qty
  StarTech.com SATA to IDE Hard Drive Adapter StarTech.com SATA to IDE Hard Drive Adapter
quicklinx: 7P1VWS00 | Mfr#: SAT2IDEADP
Available £25.99
feature value
Type Dock
Brand StarTech.com
Price Range Inc VAT 0 - 50
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
