Mount two displays on your desk surface or through a grommet, with adjustable height and cable management. The ARMDUAL Articulating Dual Monitor Arm lets you mount two displays to your desk or table, with extension, tilt, pan, swivel, pivot and height adjustments.
The desk-mount monitor arm offers a wide range of motion on several axes, giving you the freedom to place your displays side-by-side, spread apart, back-to-back or anywhere in between. For viewing longer pages or blocks of code without scrolling, the dual arm also supports landscape to portrait display rotation for either monitor.
Mounting your displays on a dual monitor arm above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 24" displays up to a maximum weight capacity of 30lbs (13.6kg) per arm, the dual arm monitor mount holds your displays with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole, for a versatile dual-monitor mounting solution.
Product Description | StarTech.com Desk Mount Dual Monitor Arm - Articulating - Supports Monitors 12" to 24" - Adjustable VESA Monitor Arm - Grommet or Desk Mount - Black (ARMDUAL) mounting kit - adjustable arm - for 2 LCD displays - black | Product Type | Mounting kit (adjustable arm) - desk-mountable | Tilt | -90° to 90° | Pan | -90° to 90° | Rotation | 360° | Adjustments | Height, pan, tilt, swivel, rotation | Weight | 4 kg | Recommended Use | 2 LCD displays | Recommended Display Size | 12"-24" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 13.6 kg | Material | Plastic, steel | Colour | Black | Package Content | 8 x M4x12 screws, allen wrench (4mm), 8 x spacers, desk clamp, grommet plate, 2 x cable-management clips, allen wrench (2.5mm), DEK, 2 x cover plates, 8 x M4x25 screws, 2 x M6x12 screws, 2 x M6 washers, 4 x gasket cushions, allen wrench (6mm) | Manufacturer Warranty | 5-year warranty | Designed For | P/N: ACCSMNT, ARMSTS, ARMSTSLG, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV |
General | |
Weight | 4 kg |
Colour | Black |
AV Furniture | |
Type | Mounting kit |
Design | Adjustable arm |
Placing / Mounting | Desk-mountable |
Cable Management | Integrated cable management |
Pan | -90° to 90° |
Rotation | 360° |
Dimensions & Weight Details | |
Shipping Dimensions (WxDxH) / Weight | 4.9 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Compatibility Information | |
