Click to visit BT.com
StarTech.com 2 Port USB DVI KVM Switch
StarTech.com StarTech.com 2 Port USB DVI KVM Switch
Usually dispatched within 3 working days
Quicklinx: 5D34WS00
Mfr#: SV211KDVIGB
£79.29
This USB DVI KVM Switch provides access and control of two DVI enabled, USB controlled computers, as well as independent audio/microphone switching that allows an uninterrupted audio experience, even when switching back and forth between computers.
The perfect KVM switch for multimedia applications, SV211KDVIGB supports both digital and analog video signal transmissions for display resolutions of up to 1900x1200 (digital) and 2048x1536 (analog). The switch also features an integrated USB 2.0 hub that allows you to share two high-speed USB devices between computers.
Compatible with Mac, Linux or PC Based computers, the DVI KVM switch (SV211KDVIGB) is a great addition for a broad range of environments including SOHO (Small or Home Offices), gaming, multimedia production workstations and more, and features a compact form factor design that helps preserve valuable deskspace.
A complete, out-of-the-box solution, this DVI KVM Switch (SV211KDVIGB) includes two 4 ft. DVI/Audio & Mic combo cables that simplify computer connection to the switch and help to eliminate the cable clutter that could result from using multiple cables.
Image gallery
Select any thumbnail below to view a larger image.
StarTech.com 2 Port USB DVI KVM Switch with Audio and Cables - KVM / audio / USB switch - 2 ports - desktop
KVM / audio / USB switch - 2 ports - USB
Enclosure Type
Desktop
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
USB 1.1, USB 2.0
15.4 cm x 6.6 cm x 2.7 cm
White
United Kingdom
2 years warranty
Enclosure Type
Desktop
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
USB 1.1, USB 2.0
Display / video : 2 x DVI-Analog/Digital - 29 pin combined DVI , Hi-Speed USB : 2 x 4 PIN USB Type B , Display / video : 1 x DVI-Analog/Digital - 29 pin combined DVI , Hi-Speed USB : 2 x 4 PIN USB Type A , Microphone : 1 x mini-phone 3.5mm , Speakers : 1 x mini-phone stereo 3.5 mm
Power adapter - external
15.4 cm
6.6 cm
2.7 cm
White
2 x USB cable - 1.2 m , 2 x keyboard / mouse / video / audio cable - 1.2 m
CE, FCC, RoHS
United Kingdom
Software Included
Drivers & Utilities
2 years warranty
Service & Support Details
feature value
Type KVM / audio / USB switch
Connectivity KVM
Ports 2
Brand StarTech.com
Price Range Inc VAT 50 - 100
