Click to visit BT.com
StarTech.com 2 Port PCIExpress USB 3.0 Card
StarTech.com StarTech.com 2 Port PCIExpress USB 3.0 Card
4 In stock
Quicklinx: 6LB2WS00
Mfr#: PEXUSB3S2
£25.27
Add 2 USB 3.0 ports to your desktop computer through a PCI Express expansion slot. Providing speeds up to 10x faster than that of USB 2.0, this PCI Express USB 3.0 card enables you to access your data and transfer files much faster than USB 2.0, by adding two USB 3.0 ports to your PCI Express capable PC.
Featuring a native NEC PCI Express host controller chipset, the USB 3.0 standard supports transfer rates of up to 5Gbps, while still providing connectivity and support for the older USB 2.0 (480Mbps) and 1.1 (12Mbps) devices.
In addition to providing a much faster transfer rate the PEXUSB3S2 USB 3.0 card also supplies 900mA of power per USB port, allowing more and more external devices to operate without the need of an additional power source.
Image gallery
Select any thumbnail below to view a larger image.
StarTech.com 2 Port PCI Express SuperSpeed USB 3.0 Card Adapter - USB adapter - 2 ports
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
12.1 cm x 7.6 cm x 1.9 cm
60 g
Ports Qty
2 ports
USB, Hi-Speed USB, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
1 x µPD720200 - NEC
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows 2000, Microsoft Windows Server 2003, Microsoft Windows Vista / XP / 7
P/N: USB3S2SATA, SAT3510BU3
Plug-in card
PCI Express x1
12.1 cm
7.6 cm
1.9 cm
60 g
Wired
Data Transfer Rate
5 Gbps
Processor / Memory
1 x µPD720200 - NEC
2 x SuperSpeed USB 3.0 - 9 pin USB Type A
Compatible Slots
1 x PCI Express x1
FCC, RoHS
Software Included
Drivers & Utilities
Service & Support Details
Limited warranty - lifetime
50 °C
0 - 80%
StarTech.com 3.5in SuperSpeed USB 3.0 SATA External Hard Drive Enclosure w/ Fan, SuperSpeed USB 3.0 SATA Adapter Cable for 2.5in or 3.5in Hard Drives
Accessories
1-4 products displayed out of 4
  product description   In stock inc VAT qty
  StarTech.com 1.8m USB 3.0 Cable AtoA - M/M StarTech.com 1.8m USB 3.0 Cable AtoA - M/M
quicklinx: 6LB3WS00 | Mfr#: USB3SAA6
Usually shipped in 3 days £8.52
  StarTech.com 3m USB 3.0 Cable A to B - M/M StarTech.com 3m USB 3.0 Cable A to B - M/M
quicklinx: 6LB4WS00 | Mfr#: USB3SAB10
Usually shipped in 3 days £9.73
  StarTech.com 1m USB 3.0 Cable A to B - M/M StarTech.com 1m USB 3.0 Cable A to B - M/M
quicklinx: 6LB5WS00 | Mfr#: USB3SAB3
Usually shipped in 3 days £7.64
  StarTech.com 1.8m USB 3.0 Cable AtoB - M/M StarTech.com 1.8m USB 3.0 Cable AtoB - M/M
quicklinx: 6LB6WS00 | Mfr#: USB3SAB6
Usually shipped in 3 days £8.54
feature value
Type USB adapter
Compatibility PC
Interface PCI Express x1
Brand StarTech.com
Stock Status In Stock
Price Range Inc VAT 0 - 50
