Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
Quicklinx: 5D3KWS00
Mfr#: HSB220SAT25B
Standard delivery Delivered within 3-5 working days
29 in stock
£31.20
Easy, trayless removal and insertion of dual 2.5in SATA hard drives from single 3.5in bay. This 3.5in SATA hard drive hot-swap bay allows you to install two 2.5in SATA hard drives (HDD) or solid state drives (SSD) in an available/unused 3.5in floppy drive bay.
Featuring a convenient "no mounting required /easy eject" feature (like a tape cartridge or floppy disk), the hard drive hot swap bay doesn't require that the drives be installed in a tray - making it the ideal solution for quick and easy drive removals and insertions as part of a system building process, or integration into rackmount systems or industrial environments.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Also a perfect addition for operating system image deployment and any task that requires being able to quickly access large volumes of data on the fly, the hot swap bay provides everything you need to expedite important projects while maintaining a reliable storage solution.
With support for SATA HDD speeds up to 6.0 Gbps, this backplane is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane - storage bay adapter
Storage bay adapter
Expansion Bays
2 x hot-swap - 2.5"
Compatible Bays
1 3.5"
Product Material
Aluminium
10.2 cm x 13.4 cm x 2.4 cm
283 g
2 years warranty
Storage bay adapter
Product Material
Aluminium
Bays
2 x hot-swap - 2.5"
2 x SATA 3Gb/s - 15 pin Serial ATA power , 2 x SATA 3Gb/s - 7 pin Serial ATA
2 storage - Serial ATA-300 - 15 pin Serial ATA power , 2 storage - Serial ATA-300 - 7 pin Serial ATA
Compatible Bays
1 x internal 3.5"
FCC, RoHS
2 years warranty
Service & Support Details
10.2 cm
13.4 cm
2.4 cm
283 g
5D3K StarTech.com 24" Serial ATA Cable In Stock £3.93
5D3K StarTech.com 18in SATA Serial ATA Cable In Stock £3.73
Price Range Inc VAT: 0 - 50
