Turn a 2.5in SATA hard drive into a complete external storage solution over USB 2.0.
The SAT2510SCB External Hard Drive Enclosure transforms any 2.5" SATA (SATA, SATA II, SATA III) hard drive or solid state drive (SSD) into a portable USB external hard drive. Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
Designed to provide convenience and portability, the hard drive enclosure features a built-on USB 2.0 cable and a durable yet lightweight aluminum construction that fits perfectly in your pocket or laptop bag when not in use.
To simplify connection to the host desktop or laptop computer, the enclosure can be powered through its built-on USB connection, eliminating the need for an external power supply and having to find a suitable power outlet while making it easier to backup data or load stored files.
Product Description | StarTech.com 2.5 USB SATA Hard Drive Enclosure w/ Integrated USB cable - storage enclosure - SATA 3Gb/s - USB 2.0 | Device Type | Storage enclosure - external | Bus Type | USB 2.0 | Colour | Silver | Expansion Bays | 1 x internal - 2.5" x 1/8H | Hard Drive Form Factor Compatibility | 2.5" | Interface | SATA 3Gb/s | Data Transfer Rate | 480 KBps | Supported Devices | Hard drive | Product Material | Aluminium | Power Source | Additional USB, USB bus | System Requirements | UNIX, Linux, Apple MacOS X 10.x, Apple MacOS 9.x or later, Microsoft Windows 7, Microsoft Windows Vista / 2000 / XP | Dimensions (WxDxH) | 13.1 cm x 8.4 cm x 1.6 cm | Weight | 145 g | Manufacturer Warranty | 2-year warranty |
General | |
Host Bus | USB 2.0 |
Colour | Silver |
Storage Controller | |
Processor | No CPU |
Expansion / Connectivity | |
Interfaces | 1 x SATA 3Gb/s |
Connections | 1 x USB 2.0 |
Miscellaneous | |
Included Accessories | Carrying case |
Cables Included | 1 x USB cable - integrated - 5 cm |
Features | Tested with up to 500GB hard drives |
Compliant Standards | FCC, RoHS |
Power | |
Software / System Requirements | |
OS Required | UNIX, Linux, Apple MacOS X 10.x, Apple MacOS 9.x or later, Microsoft Windows 7, Microsoft Windows Vista / 2000 / XP |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 13.1 cm |
Depth | 8.4 cm |
Height | 1.6 cm |
Weight | 145 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 10 - 90% |
