Sony VPL-EX315 XGA 4200lm RGB HDMI 3LCD Projector
free standard delivery
Key features
  • Bright, clear images
  • 3LCD BrightEra technology
  • XGA resolution
  • Powerful audio
  • Energy efficient with long-lasting lamp life
  • Advanced energy-saving
Product codes
chevron icon
chevron icon
This projector is ideal for mid-sized or larger classrooms and meeting rooms. Quiet, compact and powerful, it delivers bright, detailed XGA resolution images with significant color light output that can be seen clearly even in bright rooms, with 3LCD technology assuring natural, vivid colors. It is an ideal partner for integrated AV / IT environments, expanding your connectivity options with dual HDMI ports and direct USB display connection. A convenient input labeling makes life simpler, confirming on screen the name of connected devices. Add this projector to a network and see presentations from up to four connected computers simultaneously. Control the projector remotely from smartphones and tablets. You don't even need to bring a PC to meetings - just slip in a USB thumb drive and start presenting. A range of energy-saving features and long-lasting lamp life contribute to low ownership costs. Maintenance is simplified by a rear lamp access feature.
chevron icon
Product Description Sony VPL-EX315 - 3LCD projector - LAN
Device Type 3LCD projector
Built-in Devices Speaker
Brightness 3800 lumens
Brightness (Colour) 3800 lumens
Contrast Ratio 3300:1
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Bulb type Ultra high-pressure mercury 225 Watt
Bulb life cycle Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 304 Watt
Dimensions (WxDxH) 36.5 cm x 25.2 cm x 96.2 cm
Weight 4 kg
chevron icon
Accessories
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
