The SmartBand is an innovative life logging wrist band that lets you keep track of everything you do - your movements, your communications, your entertainment. Wearable technology for wherever you go, around the clock. Log special moments and watch your life played back to you on your Android smartphone or tablet.
Product Description | Sony SmartBand SWR10 activity tracker - 256 KB - black | Product Type | Activity tracker | Tracking Data | Speed, activity, sleep activity, steps taken | Connectivity | NFC, Bluetooth | Processor | ARM Cortex-M0 | Storage | 256 KB | Notifications | Missed calls | Features | Music remote handling, Micro-USB (charging only) | Supported Host Device OS | Android | Battery | Lithium polymer | Battery Run Time | Up to 120 hours | Colour | Black | Dimensions (WxDxH) | 15.3 mm x 7.8 mm x 40.7 mm | Weight | 6 g | Designed For | XPERIA C3, E3, M2 Aqua, T3, Z2 |
General | |
Supported Host Device OS | Android 4.4 (KitKat) or later |
Colour | Black |
Storage | |
Capacity | 256 KB |
Connectivity | |
Wireless Interface | NFC, Bluetooth 4.0 |
CPU | |
Manufacturer | ARM |
Type | Cortex-M0 |
RAM | |
Size | 16 KB |
Battery | |
Technology | Lithium polymer |
Run Time (Up To) | 120 hours |
Standby Time | 120h |
Recharge Time | 1 hour |
Dimensions & Weight | |
Details | Wrist strap: 250 mm x 15 g , Wrist strap: 214 mm x 14 g |
Miscellaneous | |
Preloaded Software | Smart Alarm |
Vibrating Alert | Yes |
Protection | Dustproof, waterproof |
Compliant Standards | IP58 |
Included Accessories | USB charging cable, clip, 2 wrist straps |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 5 - 99% |
Compatibility Information | |
Designed For | Sony XPERIA C3, E3, M2 Aqua, T3, Z2 |
