Click to visit BT.com
Sony DAVDZ280 Home Theatre with iPod Dock
Sony Sony DAVDZ280 Home Theatre with iPod Dock
Quicklinx: 5GR4WS00
Mfr#: DAVDZ280.CEK
Indulge yourself in superior sound and image quality with the DAV-DZ280 HDMI BRAVIA Theater System. Watch your favorite movies or listen to music with enhanced sound quality thanks to the 24-bit S-master digital amplifier, and Digital Cinema Auto Calibration (DCAC) technology. This automatically adjusts for speaker placement, distance and delay. Boasting 850W power, HDMI output with 1080p upconversion, and a supplied iPod cradle to playback music and video content from your iPod, the DAV-DZ280 ensures an amazing home audio-video experience at the touch of your fingertips.
Sony DAV-DZ280 - home theatre system - 5.1 channel
Home theatre system
Components
DVD player / AV receiver, speaker system
Enclosure Colour
Sound Output Mode
Surround Sound
Built-in Decoders
Dolby Pro Logic II, Dolby Digital, DTS decoder
Video Conversion/Scaling
Analogue to HDMI up conversion
Sound Effects
Dynamic Bass
Surround System Class
5.1 channel
Output Power
850 Watt
Radio System
Radio tuner - FM - 20 preset stations
DVD
DVD player - NTSC, PAL
Digital Player (Recorder)
WMA, AAC, MP3
Speaker(s)
2 x right/left channel speaker - external , 1 x centre channel speaker - external , 2 x right/left rear channel speaker - external , 1 x subwoofer - external
Remote Control
Universal remote control - infrared
AC 230V ( 50/60 Hz )
Home theatre system
Dimensions (WxDxH) / Weight
Speaker system : right/left channel speaker : 10.3 cm x 9.4 cm x 16.4 cm / 0.5 kg , Speaker system : right/left rear channel speaker : 10.3 cm x 9.4 cm x 16.4 cm / 0.5 kg , Speaker system : centre channel speaker : 26.5 cm x 7.7 cm x 9.4 cm / 0.7 kg , Speaker system : subwoofer : 16.8 cm x 32.5 cm x 30 cm / 5.3 kg , DVD player / AV receiver : 43 cm x 39 cm x 6.6 cm / 4.3 kg
Enclosure Colour
Audio System
Components
Sound Output Mode
Surround Sound
Built-in Decoders
Sound Effects
Dynamic Bass
5.1 channel
Output Power / Total
850 Watt
Amplifier Output details
142 Watt - 3 Ohm - at 1 kHz - THD 10% - 2 channel(s) ( front ) , 142 Watt - 3 Ohm - at 1 kHz - THD 10% - 1 channel(s) ( centre ) , 142 Watt - 3 Ohm - at 1 kHz - THD 10% - 2 channel(s) ( rear ) , 140 Watt - 3 Ohm - at 80 Hz - THD 10% - 1 channel(s) ( subwoofer )
Built-in clock
Sleep timer
Timer
Sleep
Built-in Display
Fluorescent
Display Dimmer
Additional Features
On-screen display, auto sound calibration, USB direct input
Signal Processing Features
Upscaling via HDMI
Up to 1080p
Connectors
Headphone Jack
Speaker System
Speaker(s)
2 x right/left channel speaker - external - 3 Ohm - wired , 1 x centre channel speaker - external - 3 Ohm - wired , 2 x right/left rear channel speaker - external - 3 Ohm - wired , 1 x subwoofer - external - 3 Ohm - wired
Driver Details
Right/left channel speaker : 1 x full-range driver - 65mm , Right/left rear channel speaker : 1 x full-range driver - 65mm , Centre channel speaker : 1 x full-range driver - 65mm , Subwoofer : 1 x subwoofer driver - 160mm
Radio System
Radio tuner - FM - digital radio tuner
Tuner Frequency Range
FM: 87.5 - 108 MHz
Tuning Display
Fluorescent display
Preset Station Qty
20 preset stations
FM Preset Station Qty
20 preset stations
Supported RDS Functions
PS
DVD
DVD player
Media Format
CD-R, CD-RW, SACD, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD, Video CD, DVD+R DL ( NTSC, PAL )
Video D/A Converter
12bit / 108MHz
CD Playback Modes
Programme play, repeat all, random play / shuffle, one track repeat
Supported Digital Audio Standards
MP3
Supported Digital Video Standards
DivX, MPEG-4
Upscaling
Output Resolution
1080i, 720p, 1080p
Parental lock, progressive scanning, JPEG photo playback
Digital player / recorder
WMA, AAC, MP3
ID3 Tags Support
Additional Features
JPEG photo playback, MP3 direct encoding, USB flash drive playback, USB flash drive recording
Remote Control
Connector Type
1 x SCART ( 21 PIN SCART ) - rear , 1 x HDMI output ( 19 pin HDMI Type A ) - rear , 1 x USB ( 4 PIN USB Type A ) - front , 1 x audio line-in ( mini-phone stereo 3.5 mm ) - front , 1 x FM antenna - rear , 1 x headphones ( mini-phone stereo 3.5 mm ) - front
FM antenna
Power supply - internal
150 Watt
Power Consumption Stand by / Sleep
0.3 Watt
