ITEM | QTY | PRICE |
Samsung 2TB 980 PRO PCIe M.2 SSD
4 | £850.88 |
Thrilling entertainment.
4K HDR.
Thrilling entertainment with 4K HDR. Sony Smart TV delivers exciting content in 4K HDR. Even 2K pictures are upscaled to near 4K quality with sharp details and billions of real-world colors, reproduced by Sony 4K Processor X1. Clear, natural sound brings movies and music to life for a thrilling experience.
Recreating pictures. Redefining clarity.
Even your favourites in 2K and HD are upscaled close to 4K quality, thanks to 4K X-Reality™ PRO.
Sound with great bass
X-Balanced Speaker™ was created to fit the TV’s slim design while powering movies and music with clear sound.
A thrillingly real cinema experience
More drama, more realism. Dolby Vision™ brings scenes authentically to life while Dolby Atmos™ fills your room with expansive acoustics.
Entertainment you love. With help from Google.
Google TV brings together movies, shows, and more from across your apps and subscriptions and organises them just for you.
Product Description | Sony Bravia KD-50X75WL X75WL Series - 50" Class (49.5" viewable) LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 50" | Diagonal Size | 49.5" | Colour | Hairline black | Platform | Google TV | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | Input Video Formats | 480p, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 1080/50p, 1080/60p, 1080/30p, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p | HDR Format | HDR10, Dolby Vision | HDR Technology | Hybrid Log-Gamma (HLG) | Frame Rate & Enhancement Technology | Motionflow XR 200 technology, Motionflow XR 240 technology, 60 Hz Native Refresh Rate, 50 Hz Native Refresh Rate | Video Interface | Composite, HDMI | HDMI Ports Qty | 4 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | Direct LED frame dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2 | Internet Streaming Services | Voice Search | Picture Enhancements | Live Color, 4K X-Reality PRO Engine, Dynamic Contrast Enhancer, Auto HDR Tone Mapping | Speaker System | 2 speakers | Sound Effects | DTS Digital Surround | Platform | Apple HomeKit | Storage Capacity | 32 GB | USB | 2 ports | Included Accessories | Remote control | Voltage | AC 220-240 V (50 Hz) | Energy Class | Class F | Power Consumption Stand by | 0.5 Watt | Dimensions (WxDxH) - without stand | 112.6 cm x 7 cm x 65.3 cm | Weight | 12.1 kg |
General | |
Energy Class (HDR) | Class G |
Power Consumption SDR (On mode) | 69 kWh/1000h |
Power Consumption HDR (On mode) | 90 kWh/1000h |
Series | X75WL Series |
Model Year | 2023 |
Operating System | Android TV |
HDR Capable | Yes |
Video Processor | 4K X1 |
TV Tuner Presence | Yes |
Sensors | Light sensor |
Modes | Game mode, Cinema mode, photo mode, Standard mode, Vivid mode, Graphics mode, Custom mode, Auto Low Latency Mode (ALLM), Dolby Vision bright mode, Dolby Vision dark mode, Dolby Vision vivid mode, Auto Genre Picture Mode |
Design | Narrow Bezel Design |
Dimensions | Without stand |
Width | 112.6 cm |
Depth | 7 cm |
Height | 65.3 cm |
Weight | 12.1 kg |
Enclosure Colour | Hairline black |
Display | |
LCD Backlight Technology | Direct LED - frame dimming |
Display Menu Language | Multilingual |
Features | Audio Description (AD), sleep timer, Chromecast built-in, CalMAN auto calibration support, Apple AirPlay support, screen reader, text magnification, BRAVIA CAM support, USB recording, ECO Dashboard |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Stand Colour | Black |
Stand Features | Slim wedged stand |
Flat Panel Mount Interface | 200 x 200 mm |
VESA Compatibility | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Closed Caption Capability | Yes |
Media Player | |
Supported Video Formats | MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, WebM, HEVC, VP8 |
Supported Audio Formats | MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), LPCM, ASF, OGG, AC4 |
Supported Pictures Formats | JPEG |
USB Port | Yes |
USB Ports Qty | 2 |
Configuration | 32 GB |
Remote Control | |
Type | Remote control |
Battery Included | Yes |
Audio System | |
Digital Audio Format | DTS digital output, Dolby Atmos, Dolby Audio |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Audio Return Channel (ARC), BRAVIA Sync, Bass Reflex Speaker System, Enhanced Audio Return Channel (eARC), Room Compensation |
Speakers | 2 x speaker - 10 Watt |
Driver Details | Speaker: 2 x full-range driver |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac |
Bluetooth Version | Bluetooth 4.2 |
Connect & Share | Bluetooth Human Interface Device (HID) |
Application Store | Google Play |
Connections | |
Connector Type | 4 x HDMI - side , 2 x USB - side , Composite video input - side , Digital audio output (optical) - side , LAN - side |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Compliant Standards | CEC, HDCP 2.3 |
Power | |
Power Device | Power adapter |
Input Voltage | AC 220-240 V (50 Hz) |
Auto On/Off | Yes |
Features | On/off timer |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 112.6 cm x 7 cm x 65.3 cm x 12.1 kg , Panel with stand - 112.6 cm x 26.7 cm x 71.8 cm x 12.3 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 124 cm |
Depth (Shipping) | 14.1 cm |
Height (Shipping) | 78.2 cm |
Weight (Shipping) | 17 kg |
