Click to visit BT.com
Seagate 500GB Momentus 2.5" SATA-300 7200RPM 16MB
Seagate Seagate 500GB Momentus 2.5" SATA-300 7200RPM 16MB
Quicklinx: 68KDWS00
Mfr#: ST9500420AS
The Seagate Momentus 7200.4 drive delivers the highest available capacity and performance in a laptop hard drive and draws only .05 percent more power than a 5400-rpm laptop drive.
Seagate Momentus 7200.4 ST9500420AS - hard drive - 500 GB - SATA-300
Hard drive - internal
500 GB
2.5" x 1/8H
Serial ATA-300
Data Transfer Rate
300 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
QuietStep, Native Command Queuing (NCQ), Ramp Load, Perpendicular Magnetic Recording (PMR) , S.M.A.R.T.
7 cm x 10 cm x 9.5 mm
110 g
Microsoft Certification
Compatible with Windows 7
1 year warranty
500 GB
2.5" x 1/8H
Serial ATA-300
Buffer Size
16 MB
7 cm
10 cm
9.5 mm
110 g
Performance
Drive Transfer Rate
300 MBps (external)
Average Latency
4.17 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x Serial ATA-300 - 7 pin Serial ATA
Compatible Bays
1 x internal - 2.5" x 1/8H
1 year warranty
Service & Support Details
Limited warranty - 1 year
60 °C
Shock Tolerance
350 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
