ITEM | QTY | PRICE |
Samsung 2TB 980 PRO PCIe M.2 SSD
4 | £850.88 |
The 12th generation Barracuda® hard drive continues a long tradition of Seagate technology leadership resulting in new capacity milestones, faster performance and rock-solid reliability. The drive delivers 500GB-per-disk densities with the fast performance and huge capacities to power today's storage-hungry applications at prices more affordable than ever!
Key Features and Benefits
Product Description | Seagate Desktop HDD ST3500413AS - hard drive - 500 GB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 500 GB | Form Factor | 3.5" x 1/4H | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 16 MB | Spindle Speed | 7200 rpm | Features | Native Command Queuing (NCQ), Seagate Think Green, Perpendicular Magnetic Recording (PMR) | Dimensions (WxDxH) | 10.2 cm x 14.7 cm x 2 cm | Weight | 0.54 kg | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 500 GB |
Bytes per Sector | 512 |
Width | 10.2 cm |
Depth | 14.7 cm |
Height | 2 cm |
Weight | 0.54 kg |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Seek Time | 8.5 ms (average) |
Average Latency | 4.17 ms |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Start / Stop Cycles | 50,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 3.5" x 1/4H |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 5 - 95% |
Shock Tolerance | 70 g @ 2ms (operating) / 350 g @ 1ms (non-operating) |
