Click to visit BT.com
Seagate 2TB Barracuda Green SATA-600 64MB 5900RPM 3.5"
Seagate Seagate 2TB Barracuda Green SATA-600 64MB 5900RPM 3.5"
Quicklinx: 78H7WS00
Mfr#: ST2000DL003
The company that has provided the world with product innovation over 12 generations of desktop drives has turned its focus to the increasing customer needs for low-power drives. Meet the Seagate Barracuda LP family, the low-power drive with rock-solid performance and whisperquiet, super-cool operation.
Best-Fit Applications
  • Direct Attached Storage devices-USB/FireWire/eSATA
  • Network Attached Storage devices and Windows storage servers
  • Eco friendly PCs
  • High-capacity desktop storage
Barracuda® Green drives from Seagate save you time. Available now with SATA 6Gb/s interface and 64MB cache and combined with the industry's only 5900-RPM spin speed, you can be sure you're getting the best performance in the green-power drive category.
Seagate SmartAlign™ technology simplifies your transition to the Advanced Format (AF), 4K standard. There is no need for time-consuming integration utilities required by similar AF drives.
Key Features and Benefits
  • A unique 5900-RPM speed delivers the fastest-performance eco friendly drive available.
  • Seagate SmartAlign technology allows you to get all the benefits of the new Advanced Format 4K sector standard without any hassle-no utilities, no extra steps.
  • The SATA 6Gb/s interface and 64MB cache maximize performance.
  • Low power consumption combined with leadership in the use of recycled materials means you don't have to sacrifice environmental stewardship for performance.
  • Cool, quiet operation
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the Seagate 2TB Barracuda Green SATA-600 64MB 5900RPM 3.5"
Seagate Barracuda Green ST2000DL003 - hard drive - 2 TB - SATA-600
Hard drive - internal
2 TB
3.5" x 1/3H
Serial ATA-600
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5900 rpm
Native Command Queuing (NCQ)
10.2 cm x 14.7 cm x 2.6 cm
0.64 kg
1 year warranty
2 TB
3.5" x 1/3H
Serial ATA-600
Buffer Size
64 MB
Bytes per Sector
4096
10.2 cm
14.7 cm
2.6 cm
0.64 kg
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
144 MBps
Seek Time
12 ms (average)
Average Latency
4.16 ms
Spindle Speed
5900 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x Serial ATA-600 - 7 pin Serial ATA
Compatible Bays
1 x internal - 3.5" x 1/3H
1 year warranty
Service & Support Details
Limited warranty - 1 year
60 °C
Shock Tolerance
80 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
