Click to visit BT.com
Seagate 1TB Blackarmor NAS 110 SATA-300 Gigabit Ethernet
Seagate Seagate 1TB Blackarmor NAS 110 SATA-300 Gigabit Ethernet
Discontinued, only used stock available
Quicklinx: 68WYWS00
Mfr#: ST310005MND10G-RK
BlackArmor® NAS 110: Desktop storage with an easy USB interface.
The BlackArmor NAS 110 server is a network attached storage solution designed to provide centralized storage, data backup and media streaming for up to 10 PCs. Help protect important data with automatic full-system backup, SafetyDrill+ bare metal recovery software and powerful hardware-based encryption.
  • Store and access files from a central, secure location
  • Remotely access and manage files
  • Stream media to devices and computers
  • Perform full-system backups of PCs and use Time Machine® software for Mac® computers.
With centralised storage and automatic full-system backup for up to 10 PCs, BlackArmor NAS 110 is serious hardware. And with easy media streaming, remote access and an intuitive interface, it makes accessing and sharing your content extremely easy.
Protect up to 10 PCs
With a data capacity of 2TB, BlackArmor NAS 110 lets you protect every PC in your home (or small business), keeping files secure with powerful hardware-based encryption. And features such as automatic full-system backup and SafetyDrill+™ bare metal recovery software provide critical protection for your important data.
Web-based server management
In addition to included backup software, BlackArmor NAS 110 lets you manage data remotely using the Web-based BlackArmor Discovery tool. With a single click, you can view or map shared volumes to your computer, access the Web-based user interface or back up the PC you are working from.
OneTouch® backup
Back up important data from USB drives and digital cameras quickly. Just plug in and press the OneTouch button. With two external USB ports, you can connect external drives, share a printer or use an uninterrupted power supply to safeguard against power failure.
Stream your content
BlackArmor NAS 110 also lets you stream media files to DLNA®-compliant devices or computers running iTunes®. So you have an easy way to centralise your content and display it simultaneously on multiple devices.
Works on both PCs and Macs
To help protect all the files on your PC, our software package provides automatic, incremental and full-system backup. Use Time Machine to back up files on your Mac computer to the BlackArmor server.
Image gallery
Select any thumbnail below to view a larger image.
Seagate BlackArmor NAS 110 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
1 TB
1 (installed) / 1 (max)
6.1 cm x 14.7 cm x 17.6 cm
1.22 kg
Storage Controller
- Serial ATA-300
Hard Drive
1 x 1 TB standard Serial ATA-300
Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet
Microsoft Windows Vista / XP, Apple MacOS X 10.4.11 or later
Microsoft Certification
Compatible with Windows 7
NAS server
Host Connectivity
Gigabit Ethernet
1 TB
6.1 cm
14.7 cm
17.6 cm
1.22 kg
Storage Controller
Controller Interface Type
Serial ATA-300
Supported Devices
Hard drive
Max Storage Devices Qty
1
Hard Drive
Standard
1 x 1 TB
Interface Type
Serial ATA-300
Network adapter
Network / Transport Protocol
FTP, Bonjour
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Apple Bonjour Protocol, Microsoft CIFS, Network File System (NFS), FTP, HTTP, HTTPS
E-mail alert, FTP server
Expansion Bays
1 (total) / 0 (free) x internal
1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x Hi-Speed USB - 4 PIN USB Type A
1 x network cable - 2 m
Software Included
Seagate BlackArmor Discovery, Seagate BlackArmor Backup
System Requirements Details
Windows XP/Vista - Pentium III - 500 MHz - RAM 256 MB
Buy used stock
Ref Condition Packaging Accessories Manuals Software Functional
68WY 1806  Warranty repaired item.  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £103.48
All used stock has a 90 day warranty
Legend
  • Packaging Packaging
  • Accessories Accessories
  • Manuals Manuals
  • Software Software
  • Functional Functional
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
feature value
Capacity 1TB
Interface Ethernet
Interface Fast Ethernet
Interface Gigabit Ethernet
Brand Seagate
Stock Status Used Stock
Price Range Inc VAT 100 - 150
