Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
Sapphire Technology AMD Radeon R9 280X 870MHz 3GB PCI-Express 3.0 HDMI Dual-X
Quicklinx: 90MZWS00
Mfr#: 11221-00-40G
Hurry, only 2 left in stock!
Always looking to deliver the best solutions to the user, even the base model in this family features SAPPHIRE's highly acclaimed Dual-X cooler. Dual-X, with its two aerofoil fans, and graduated heatpipes, is a design which received industry acclaim in the previous generation of products. The SAPPHIRE R9 280X Dual-X model is the most cost effective member of the family and yet is still overclocked compared with the reference design to give users the best possible value for money in this performance class.
Specification
  • Display Support 3 x Maximum Display Monitor(s) support
  • Output 1 x HDMI (with 3D), 1 x DisplayPort 1.2, 1 x Dual-Link DVI-D, 1 x Dual-Link DVI-I
  • GPU 870/Boost:1020 MHz Core Clock, 28 nm Chip, 2048 x Stream Processors
  • Video Memory 3072 MB Size, 384 -bit GDDR5, 6000 MHz Effective
  • Dimension 262(L)X112(W)X34(H) mm Size., 2 x slot
  • Software Driver CD, SAPPHIRE TriXX Utility
  • Accessory CrossFire™ Bridge Interconnect Cable, 8 PIN to 4 PIN Power Cable, 6 PIN to 4 PIN Power Cable
Sapphire RADEON R9 280X Dual-X OC graphics card - Radeon R9 280X - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 280X
3 GB - GDDR5
Core Clock
870 MHz
Boost Clock
1020 MHz
Stream Processors
2048
Effective Memory Clock
6 GHz
Memory Interface
384-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160 / VGA: 2048 x 1536
Max Monitors Supported
3
DVI-I (dual link) , HDMI , DVI-D (dual link) , DisplayPort
API Supported
OpenGL 4.2, DirectX 11.2
3.4 cm x 26.2 cm x 11.2 cm
Package Type
Retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 280X
Core Clock
870 MHz
Boost Clock
1020 MHz
Stream Processors
2048
Process Technology
28 nm
Max Resolution
4096 x 2160
3
API Supported
Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Unified Video Decoder (UVD) 3, AMD Stream technology, AMD App Acceleration, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, AMD Eyefinity Technology 2.0, AMD HD Media Accelerator, Dual-X cooler, Graphics Core Next (GCN), AMD ZeroCore Power technology, cutting-edge Quad HD display support, Dual Firmware Support, UEFI BIOS , HDCP
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
6 GHz
Bus Width
384-bit
Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Min RAM Size
4 GB
Required Power Supply
750 W
Additional Requirements
CD-ROM, 6-pin + 8-pin power connectors
4 pin to 6 pin power cable, 4 pin to 8 pin power cable
1 x HDMI cable - 1.8 m , 1 x CrossFire cable
Software Included
Drivers & Utilities, Sapphire TriXX, AMD Catalyst Control Center
3.4 cm
26.2 cm
11.2 cm
Package Type
Retail
