Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
Sandberg Micro WiFi USB Dongle
Customer rating:5.0*
Quicklinx: 8V5KWS00
Mfr#: 133-65
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Type: Network adapter
Express delivery Order within the next 19 hours for delivery on Tuesday
More than 50 in stock
£17.19
The Sandberg Micro WiFi USB Dongle gives you wireless network access via a USB port. The adapter allows you to connect to wireless networks wherever you have access to them - removing the need for cables or installing internal hardware.
Sandberg Micro WiFi USB Dongle - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
802.11b, 802.11g, 802.11n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, USB 1.1, USB 2.0, IEEE 802.11n
Microsoft Windows Vista / XP / 7
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Max Range Indoors
200 m
Max Range Open Space
500 m
Auto-fallback, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal integrated
1 x USB 2.0 - 4 PIN USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Software Included
Drivers & Utilities
Customer reviews
Write a review for the Sandberg Micro WiFi USB Dongle here!
5.0 1
£17.19
Good product
Reviewed by . Review Posted 18/05/2014
5 5
Ideal if you have an old adapter and are upgrading your router. The driver Cd is small but fits a ful size drive.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Wired / Wireless: Wireless
Form Factor: External
Compatibility: PC
Brand: Sandberg
Price Range Inc VAT: 0 - 50
