Click to visit BT.com
Samsung SE-506AB Blu-Ray Writer Slim Portable USB 2.0 Black
Samsung Samsung SE-506AB Blu-Ray Writer Slim Portable USB 2.0 Black
15 In stock
Quicklinx: 7RX2WS00
Mfr#: SE-506AB/TSBD
£83.98
SE-506AB features a slim and sleek design with a hi-glossy anti-scratch surface. It is 12 percent smaller than Samsung's conventional Blu-ray drive to accommodate today's hectic mobile lifestyle. The slim form factor is also supported with a USB power interface that eliminates the need for a separate electrical outlet.
The SE-506AB drive is compatible with all major operating systems, including Win7 and Mac OS. In addition, the drive features Buffer Under Run technology to prevent errors that may result from writing speeds that exceed data transfer speeds, while also enabling PC multitasking. Samsung ODD's exclusive AV connectivity technology is featured on the new SE-506AB allowing users to easily connect and play content via AV connectivity function on multimedia TVs with an available USB port.
The drive also improves upon previous ODD models, which only recognize the first sub-directory and 1000 files. The new SE-506AB model now recognizes and allows access to the fifth sub-directory and more than 3000 files.
The external drive provides a variety of speeds across different media types featuring BD Quadruple layering. Specific speeds include: 6X BD-ROM, 24X CD-ROM, 24X CD-RW reading and 6X BD-R, 6X BD-R Dual layer, 4X BD-R Quad layer, 8X DVD±R, 5X DVD-RAM, 6X DVD+R Dual layer, 6X DVD-R Dual layer, 8X DVD+RW, 6X DVD-RW recording.
As an eco-friendly product, the drive offers low-power consumption and lead-free soldering technology, a design that complies with international environmental regulations that limit the use of hazardous materials.
Read
  • CD-ROM: 8x
  • CD-R: 24x
  • CD-RW: 24x
  • DVD+R: 8x
  • DVD-R: 8x
  • DVD+R DL: 6x
  • DVD-R DL: 6x
  • DVD+RWL 8x
  • DVD-RW: 8x
  • DVD-RAM: 5x
  • BD-ROM DL: 6x
  • BD-R: 6x
  • BD-R DL: 4x
  • BD-R TL: 4x
  • BD-R QL: 4x
  • BD-RE: 4x
  • BD-RE DL: 4x
  • BD-RE TL: 4x
Write
  • CD-R: 24x
  • CD-RW: 24x
  • DVD+R: 8x
  • DVD-R: 8x
  • DVD+R DL: 6x
  • DVD-R DL: 6x
  • DVD+RW: 6x
  • DVD-RW: 6x
  • DVD-RAM: 5x
  • BD-R: 6x
  • BD-R DL: 6x
  • BD-R TL: 4x
  • BD-R QL: 4x
  • BD-RE: 2x
  • BD-RE DL: 2x
  • BD-RE TL: 2x
Access Times
  • CD-ROM: 170ms
  • DVD-ROM: 180ms
  • BD-ROM: 300ms
Dimensions
  • Dimension (W x H x D): 145mm x 19.5mm x 145mm
  • Weight: 330g
Image gallery
Select any thumbnail below to view a larger image.
Samsung SE-506AB - BDXL drive - Hi-Speed USB
BDXL drive
Enclosure Type
External
Enclosure Colour
Hi-Speed USB
14.5 cm x 14.5 cm x 2 cm
332 g
Optical Storage
BD-Writer
Read Speed
24x (CD) / 8x (DVD) / 6x (BD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) / 6x (BD-R) / 6x (BD-R DL) / 4x (BD-R QL) / 4x (BD-R TL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD±RW) / 5x (DVD-RAM) / 2x (BD-RE) / 2x (BD-RE DL) / 2x (BD-RE TL)
Buffer Underrun Protection
Super Link
BDXL drive
Enclosure Type
External
Enclosure Colour
Hi-Speed USB
14.5 cm
14.5 cm
2 cm
332 g
Optical Storage
BD-Writer
Read Speed
Write Speed
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-R DL, BD-RE, BD-RE DL, BD-ROM, BD-R QL, BD-R TL, BD-RE TL
Media Load Type
Tray
Access Time
130 ms (CD), 130 ms (DVD-ROM), 200 ms (BD)
Buffer Size
4 GB
Super Link
Blu-ray 3D
Package Type
Retail
feature value
Drive Type BDXL Writer
Enclosure Type External
Interface Hi-Speed USB
Colour Black
Type Disk drive
Brand Samsung
Stock Status In Stock
Price Range Inc VAT 50 - 100
