Click to visit BT.com
Samsung SCX4825FN 5 in 1 Mono Laser Multifunction Network Printer with Duplex
Samsung Samsung SCX4825FN 5 in 1 Mono Laser Multifunction Network Printer with Duplex
Quicklinx: 6Z32WS00
Mfr#: SCX-4825FN/SEE
Imagine a multifunction printer that meets your business needs. The SCX-4825FN is optimised simplicity, yet provides professional features increasing productivity and efficiency with duplex and network connectivity. A harmonious balance for any office. WIth the Samsung SCX-4825FN its not that hard to imagine.
Versatile 5-in-one Versatility is the key to this convenient 5-in-1 laser multifunction Printer. With all the functions you have asked for in one central device, you can print, copy, scan, fax and PC-fax conveniently and easily. The SCX-4825FN delivers high performance and maximum speed versatile enough for a professional workgroup
Intuitive Simple & Easy GUI Get everyone at work onboard quickly with simple and easy to use GUI screens. Reduce training and troubleshooting time with simple intuitive menus and buttons. The IT department can keep the user manuals because no one will need to read them to be able to print, copy, scan and fax simply and quickly
Fast FPOT Everyone wants fast printouts, but if the first page out of the printer takes too long, waiting can be very stressful. The SCX-4825FN boasts a fast frist page print time of 15.5 seconds in the sleep mode. That means that even if you are just printing one page, the results will be quick and stress free.
Efficient Duplex + ADF Convenient features increase your daily office efficiency. The 50-sheet automatic document feeder (50-sheet ADF on SCX-4825FN) saves time and speeds up copying and scanning, while giving you more control over the process. The SCX-4825FN model features duplex printing, saving time and reducing paper consumption.
Durable Max. Monthly Duty When choosing a printer, most businesses look at speed and output quality. But another important factor is the maximum monthly duty cycle. In other words, the maximum number of pages a printer can generate each month. The SCX-4825FN produces a high rate of 50000 pages a month, ensuring the availability along with the productivity of the Samsung MFP
Customisable Paper Formats The SCX-4825FN is prepared for global business with a customizable paper size tray that can handle international paper formats. Compatible paper sizes include A6, A4, A5, letter, legal, folio, oficio, executive, ISO B5, JIS B5, 3 x 5, monarch, No. 10, DL, C5 and C6. This versatile feature allows your business to be prepared for the future
Unique Corner-less Organic Design Samsung is known for sleek innovative design. The SCX-4825FN adds in another element-organic design. The overall concept is softer, rounder and more natural, adding comforting appeal to your workspace
Innovative Compact Design MFPs are convenient but take up a lot of space. The SCX-4825FN series features a compact design that will fit into any workspace. At 445 x 411 x 395mm, its neat size and sleek design give you the performance you need without the bulk
Blue Compass Navigation The innovative Blue Compass Navigation, with its signature Samsung blue glow, keeps you updated on the progress of the current task and helps you navigate the menu. The Blue Compass Navigation is easy to use and adds a striking focal point to the menu.
Quiet Printing Your business can work in peace, even when printing multiple jobs, thanks to the SCX-4825FN' quiet print levels. They have the lowest noise levels of their class, at just 49 - 52dBA for printing and copying respectively. That is quieter than a normal conversation or a telephone dial tone. Enjoy productivity and peace at the same time.
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the Samsung SCX4825FN 5 in 1 Mono Laser Multifunction Network Printer with Duplex
Samsung SCX 4825FN - multifunction ( fax / copier / printer / scanner ) ( B/W )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
G3 - plain paper
44.5 cm x 41.1 cm x 39.5 cm
14.5 kg
Printing Technology
Laser ( monochrome )
Monthly Duty Cycle (max)
50000 impressions
Max Copying Speed
Up to 12 ppm
Max Copying Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 24 ppm
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
600 x 600 dpi
Original Size
128 x 148 mm (min) - 216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
216 x 356 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
Hi-Speed USB, Ethernet 10 Base-T/100 Base-TX, USB host
Microsoft Certification
Compatible with Windows 7
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 impressions
Display
2 lines x 16 characters
44.5 cm
41.1 cm
39.5 cm
14.5 kg
Standard Memory
128 MB
Max Supported Memory
384 MB
Copying
Max Copying Speed
Up to 12 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2-up, 4-up
Printing
Max Printing Speed
Up to 24 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Error Correction Mode (ECM)
Document & Media Handling
Min Original Size
128 x 148 mm
Max Original Size
216 x 356 mm
Original Type
Sheets
50 sheets
Max Copy Size
216 x 356 mm
Supported Media Type
250 sheets
100 sheets
Paper cassette - 250 sheets - 216 x 356 mm , Output tray - 100 sheets - 216 x 356 mm , ADF - 50 sheets - 216 x 356 mm
PC Connectivity
PC Connection
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows Vista, Apple Mac OS X 10.3 - 10.5
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge ( black )
Sound Emission
26 dB (idle) / 53 dB (operating)
