Click to visit BT.com
BT.com
Wishlist
Samsung S20C300BL 19.5" 1600x900 5ms VGA DVI-D LED Monitor
Quicklinx: 8P45WS00
Mfr#: LS20C300BL/EN
Essential accessories
Marketing description is not available.
Samsung S20C300BL - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Energy Class
Class B
Aspect Ratio
Widescreen
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m2
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Transparent red
47.62 cm x 18.7 cm x 37.94 cm - with stand
2.4 kg
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
Display Type
Energy Class
Class B
Diagonal Size
19.5"
Aspect Ratio
Widescreen
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m2
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 81 kHz
Video Bandwidth
136 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
Transparent red
2.4 kg
VGA , DVI-D
Mechanical
Tilt
1 x VGA cable
Power Supply
External
AC 120/230 V ( 50/60 Hz )
14 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Samsung MultiScreen
Dimensions & Weight Details
With stand - width: 47.62 cm - depth: 18.7 cm - height: 37.94 cm - weight: 2.4 kg , Without stand - width: 47.62 cm - depth: 5.3 cm - height: 29.98 cm - weight: 2.1 kg
EPEAT Compliant
EPEAT Gold
10 °C
10 - 80% (non-condensing)
