Professional performance. Perfect price.
Reduce print costs but don't settle for less than the best. An efficient Samsung Xpress M2825ND Series gives you the speed you need to be more productive, but there's no compromise on quality. What's more, thanks to mobile printing and Easy Printer Manager software, these Printers are also designed to be easy to use.
Print fast, don't wait
However demanding your professional printing needs, a Samsung Xpress M2825ND Series gives you great results - fast. Save time by printing even complex documents at speeds of up to 28 pages per minute (PPM) thanks to a powerful 600MHz processor and 128MB of memory. With the Cortex-A5 Core, it's up to 25.6% faster than earlier models, making it one of the fastest printers in its class. That means it helps you to work faster, be more flexible and more productive.
Give a good impression with great print quality
Now impressive professional-quality prints are possible for everyone. Your Samsung Xpress M2825ND Series delivers sharp, clear prints that are sure to make a big impact. Thanks to its 4800 x 600dpi effective resolution and Rendering Engine for Clean Page (ReCP) technology, you can enjoy higher perfor-mance and quality without the need for a bulky larger printer. What's more, quality-boosting features give you more detail, smoother images and clearer text.
High-resolution printing
Even complex images and small text are delivered in fine, detailed prints, thanks to high-resolution print quality up to 4800 x 600dpi effective.
Edge enhancement
Enjoy clearer text and more vivid images thanks to edge enhancement, which gives them a far more polished and well-defined edge.
Print with more paper types for all kinds of uses
Whatever you need to print, your Samsung Xpress M2825ND Series can handle it. The small but robust printer can use a range of media up to 220 grams per square meter (gsm), including paper, labels, cards, envelopes and overhead projector (OHP) transparencies. You can easily select the paper type you need from the multipurpose (MP) tray, so it's convenient as well as flexible.
Better for your budget and the planet
Businesses can decrease toner and paper costs simply with One-Touch Eco button features that help companies limit the amount of resources needed to perform printing operations. One-Touch Eco button enables to employ N-up and duplex printing to print multiple document pages on a single sheet, skipping blank pages to reduce the amount of paper used. Toner save mode also reduces supply costs by decreasing toner use.
Cut energy and supply consumption
With Easy Eco Driver, you can make savings of up to 20% on toner and paper as well as reducing your energy usage. It helps you cut down on page elements that use high amounts of toner, such as images and bold type fonts, or lighten text so that less toner is required. You can preview and edit your documents before print-ing, to make sure that the output meets your needs in terms of efficiency and also quality. Eco Simulator also shows you the estimated reduction percentage of CO2, electricity, and paper, so you can see the difference for yourself.
Cut costs with Separated Toner System
With Samsung's Separated Toner System, the toner cartridge and imaging unit are supplied separately. This means you only need to buy the toner cartridge when it's empty, so the overall cost of running the printer - and the cost per page - is reduced. Installation is also easy, so you can spend less time maintaining your printer as well as less money. You can balance your budget as well as meet all your printing needs
Monitor and manage your printer easily
Samsung's Easy Printer Manager lets you look after your printer's settings, device status, supply ordering and faxing - all in one place. You can conveniently see error reports and monitor the status of your printer and its supplies, as well as manage settings remotely. It's all provided in one single interface that brings together all your Samsung Printer's settings and applications.
Duplex printing
Duplex printing, or printing on both sides of paper, helps ensure that a minimal amount of paper and toner are wasted. Eco Mode lets you make sure all documents use duplex printing, so you can use supplies more efficiently and reduce your impact on the environment.
Network connectivity
Connect your printer across many different PCs and other devices that are connected to a single router. With this arrangement, it's possible for you to reduce the amount of money you spend on printing devices and energy consumption, yet be as productive as ever.
Product Description | Samsung Xpress M2825ND - printer - B/W - laser | Printer Type | Workgroup printer - laser - B/W | Weight | 7.4 kg | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 28 ppm - B/W - A4 (210 x 297 mm) , Up to 29 ppm - B/W - ANSI A (Letter) (216 x 279 mm) | Max Resolution (B&W) | 4800 x 600 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, LAN | Processor | 600 MHz | RAM Installed (Max) | 128 MB | Language Simulation | PCL 5E, PCL 6, SPL (Samsung Printer Language) | Media Type | Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper, card stock | Total Media Capacity | 250 sheets | Media Handling | 250-sheet paper cassette, 1-sheet manual tray | Monthly Duty Cycle (max) | 12000 pages | System Requirements | Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.8 | Dimensions (WxDxH) | 36.8 cm x 33.45 cm x 20.2 cm |
General | |
Printer Type | Workgroup printer - laser - monochrome |
Printer | |
Connectivity Technology | Wired |
First Print Out Time B/W | 8.5 sec |
Processor | |
RAM | |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm) |
Envelope Sizes | International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm) |
Media Weight | 60 g/m² - 220 g/m² |
Media Feeders | 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² |
Output Trays Capacity | 150 sheets |
Duty Cycle | |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) - up to 1200 pages |
Compliant Standards | ISO/IEC 19752 |
Power | |
Power Device | Power supply - internal |
Power Consumption Operational | 400 Watt |
Power Consumption Stand by / Sleep | 45 Watt |
Software / System Requirements | |
OS Required | Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.8 |
Environmental Standards | |
ENERGY STAR | Yes |
Environmental Parameters | |
Sound Emission (Idle) | 26 dBA |
Sound Emission (Operating) | 50 dBA |
Dimensions & Weight | |
Width | 36.8 cm |
Depth | 33.45 cm |
Height | 20.2 cm |
Weight | 7.4 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 45 cm |
Depth (Shipping) | 41.5 cm |
Height (Shipping) | 33 cm |
