A bigger screen makes everything easier. The 12.4" Dynamic AMOLED display on this Tab S9+ is perfect for multitasking - you can be typing up a paragraph, have your research tabs open and control your music at the same time. And it's just as amazing for watching movies and playing games, thanks to the blazing-fast 120 Hz refresh rate. For getting creative, it comes with the S Pen in the box. You can make drawings and handwritten notes just like putting pen to paper. When you're done, it snaps on the back of the tablet magnetically, so you don't lose it. And because it's powered by the Snapdragon 8 Gen 2, it's got plenty of power for all your apps and games.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy Tab S9+ - tablet - Android 13 - 512 GB - 12.4" | Product Type | Tablet | Operating System | Android 13 | Display | 12.4" Dynamic AMOLED 2X - 2800 x 1752 - Multi-Touch | Processor | Qualcomm Snapdragon 8 Gen 2 (8-core) | Processor Clock Speed | 3.36 GHz | Storage | 512 GB | RAM | 12 GB | User Available Memory | Flash: 454.9 GB | Supported Flash Memory Cards | microSD, microSDHC, microSDXC | Wireless Connectivity | 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3 | Rear Camera | 13 Megapixel - wide-angle lens focus: automatic | Second Rear Camera | 8 Megapixel | Front Camera | 12 Megapixel | Navigation System | GPS/GLONASS/Galileo/BeiDou/QZSS | Security Devices | Fingerprint reader | Battery Run Time | Up to 16 hours | Dimensions (WxDxH) | 18.54 cm x 0.57 cm x 28.54 cm | Weight | 581 g | Colour | Graphite | Specific Absorption Rate (SAR) | 0.444 W/kg (body) | Manufacturer Warranty | 2-year warranty |
General | |
Display | |
Type | 12.4" Dynamic AMOLED 2X |
Resolution | 2800 x 1752 |
Colour Depth | 16 million colours |
Touchscreen | Multi-Touch |
Image Aspect Ratio | 16:10 |
Features | Eye comfort mode, 120 Hz refresh rate, Eye-Care Technology, HDR10+ |
Processor | |
Processor | Qualcomm Snapdragon 8 Gen 2 |
Number of Cores | 8-core |
Memory | |
Storage | 512 GB |
RAM | 12 GB |
Max Supported Capacity | 1 TB |
Communications | |
Security Protocols & Features | Wi-Fi Direct |
Bluetooth Profiles | Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), HID Over GATT Profile (HOGP), Telephony and Media Audio Profile (TMAP), Public Broadcast Profile (PBP) |
Rear Camera | |
Sensor Resolution | 13 Megapixel |
Focus Adjustment | Automatic |
Lens Type | Wide-angle lens |
Light Source | Flash |
Video Resolutions | 3840 x 2160 (4K) at 30 fps |
Second Rear Camera | |
Sensor Resolution | 8 Megapixel |
Lens Type | Ultra wide-angle lens |
Front Camera | |
Sensor Resolution | 12 Megapixel |
Navigation System | |
Receiver | GPS/GLONASS/Galileo/BeiDou/QZSS |
Multimedia | |
Supported Digital Audio Standards | WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID, Dolby Atmos |
Supported Digital Video Standards | AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM, MP4 |
Audio | Four speakers |
Input Device | |
Type | S Pen |
Software | |
Preloaded Software | Samsung KNOX, Samsung Smart Switch |
Expansion and Connectivity | |
Expansion Slots | 1 x microSDXC |
Interfaces | 1 x USB-C 3.2 Gen 1 |
Battery | |
Capacity | 10090 mAh |
Run Time Details | Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 16 hour(s) , Audio playback: up to 154 hour(s) |
Miscellaneous | |
Colour | Graphite |
Case Material | Reinforced aluminium |
Sensors | Accelerometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor |
Features | Water-resistant, dust-resistant, MIMO technology, fast charging, Drop Protection, tuned by AKG speakers, vapor chamber cooling system |
Included Accessories | S Pen |
Compliant Standards | IP68 |
Dimensions & Weight | |
Width | 18.54 cm |
Depth | 0.57 cm |
Height | 28.54 cm |
Weight | 581 g |
Environmental Parameters | |
Max Depth of Water Resistance | 1.5 m |
