Unreal Performance, Realized.
Always Evolving SSD
The ultimate in performance, upgraded. Faster than the 970 EVO, the 970 EVO Plus is powered by the latest V-NAND technology and firmware optimization. It maximizes the potential of NVMe bandwidth for unbeatable computing. In capacities up to 2TB, with reliability of up to 1,200 TBW.
Level up Performance
The 970 EVO Plus reaches sequential read/write speeds up to 3,500/3,300 MB/s, up to 53% faster than the 970 EVO. The latest V-NAND—which brings greater NAND performance and higher power efficiency—along with optimized firmware, a proven Phoenix controller, and Intelligent TurboWrite boost.
Unparalleled Reliability
Achieve a new level of drive confidence. Samsung’s advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable superior heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to minimize performance drops.
Product Description | Samsung 970 EVO Plus MZ-V7S1T0BW - SSD - 1 TB - PCIe 3.0 x4 (NVMe) | Type | Solid state drive - internal | Capacity | 1 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | Triple-level cell (TLC) | Form Factor | M.2 2280 | Interface | PCIe 3.0 x4 (NVMe) | Buffer Size | 1 GB | Features | TRIM support, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, TurboWrite Technology, V-NAND Technology, NVM Express (NVMe) 1.3, Samsung Phoenix Controller, S.M.A.R.T. | Dimensions (WxDxH) | 22.15 mm x 80.15 mm x 2.38 mm | Weight | 8 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 1 TB |
Width | 22.15 mm |
Depth | 80.15 mm |
Height | 2.38 mm |
Weight | 8 g |
Performance | |
SSD Endurance | 600 TB |
Internal Data Rate | 3500 MBps (read) / 3300 MBps (write) |
4KB Random Read | 19000 IOPS |
4KB Random Write | 60000 IOPS |
Maximum 4KB Random Write | 550000 IOPS |
Maximum 4KB Random Read | 600000 IOPS |
Reliability | |
MTBF | 1,500,000 hours |
Expansion & Connectivity | |
Interfaces | PCI Express 3.0 x4 (NVMe) - M.2 Card |
Compatible Bay | M.2 2280 |
Power | |
Power Consumption | 6 Watt (average) , 9 Watt (maximum) , 30 mW (idle max) |
Miscellaneous | |
Compliant Standards | IEEE 1667 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Shock Tolerance (operating) | 1500 g @ 0.5 ms half-sine |
Customer return - item has been opened but is in excellent condition
Ref: F1C3 048647 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£81.06
