Click to visit BT.com
Samsung 22" T220 Rose Red 2ms DVI TFT
Samsung Samsung 22" T220 Rose Red 2ms DVI TFT
Quicklinx: 540NWS00
Mfr#: LS22TWHSUV
Highlights of the Samsung T220 22" monitor
Screen: 22" (1680x 1050)
Brightness: 300 cd/m2
Dynamic Contrast Ratio: 20000:1
Response time: 2ms
Connectivity: VGA (HD-15), DVI
Image gallery
Select any thumbnail below to view a larger image.
Samsung SyncMaster T220 - LCD display - TFT - 22"
LCD display / TFT active matrix
Rose black
52 cm x 21.5 cm x 44.2 cm
5.8 kg
Diagonal Size
22" - widescreen
Dot Pitch / Pixel Pitch
0.282 mm
Max Resolution
1680 x 1050 / 60 Hz
Display Positions Adjustments
Tilt
Colour Support
16.7 million colours
Image Aspect Ratio
16:10
Response Time
2 ms
Image Brightness
300 cd/m2
Image Contrast Ratio
20000:1 (dynamic)
Digital Video Standard
Digital Visual Interface (DVI)
Signal Input
DVI-I, VGA
Microsoft Certification
Certified for Windows Vista
CE, DDC-2B, ISO 13406-2, RoHS
AC 120/230 V ( 50/60 Hz )
45 Watt
Environmental Standards
ENERGY STAR Qualified , EPEAT Silver
Display Type
TFT Technology
TN
52 cm
21.5 cm
44.2 cm
5.8 kg
Enclosure Colour
Rose black
Display
Diagonal Size
22" - widescreen
0.282 mm
Max Resolution
1680 x 1050 / 60 Hz
Colour Support
Max Sync Rate (V x H)
75 Hz x 81 kHz
Video Bandwidth
146 MHz
Response Time
2 ms
Controls / Adjustments
Brightness, contrast, H/V position, sharpness, colour balance, gamma correction, colour temperature
Tilt
OSD Languages
English, German, French, Italian, Portuguese, Swedish, Russian, Spanish, Turkish
Signal Input
DVI-I, VGA
OSD-Digital Display Director, Sync on Green, MagicSpeed, HDCP, MagicBright 3
Image Colour Temperature
Adjustable
Image Aspect Ratio
16:10
Image Brightness
300 cd/m2
20000:1 (dynamic)
Image Max H-View Angle
170
Image Max V-View Angle
160
Video Input
Analogue video Signal
RGB
1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI
1 x VGA cable , 1 x DVI cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Internal
45 Watt
Power Consumption Stand by / Sleep
1 Watt
Software Included
Drivers & Utilities, Natural Color Pro
EPEAT Compliant
EPEAT Silver
10 °C
10 - 80%
Accessories
1-3 products displayed out of 3
  product description   In stock inc VAT qty
  Durable 5798 Screenclean Pro Kit Durable 5798 Screenclean Pro Kit
quicklinx: 4GWZWS00 | Mfr#: 5798
In stock £8.49
  Microsoft Natural Ergo Desktop 7000 Microsoft Natural Ergo Desktop 7000
quicklinx: 4LZ6WS00 | Mfr#: WTA-00005
In stock £50.78
  Belkin 6-Outlet Compact Surge Protector Belkin 6-Outlet Compact Surge Protector
quicklinx: 4JVRWS00 | Mfr#: BZ106200UK2M
Available £19.32
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
