Click to visit BT.com
Samsung 1TB S2 Portable 2.5" USB 2.0 Portable Hard Drive (Piano Black)
Samsung Samsung 1TB S2 Portable 2.5" USB 2.0 Portable Hard Drive (Piano Black)
More than 200 in stock
Quicklinx: 74NXWS00
Mfr#: HXMU010EA/G22
£84.99 inc VAT
1TB SAMSUNG S2 Portable Hard Drive - Piano Black
Smaller and lighter than almost any other external hard drive on the market, the S2 Portable is the ideal storage solution for those who need to carry massive amounts of digital content when they're on the go. With its desktop-sized capacity, this pocket-sized wonder is powerful enough to store up to 1TB of information. The unique inclusion of a USB on-board controller reduces the drive's weight and power consumption, making it as efficient as it is compact.
  • Capacity: 1TB
  • USB On-board Technology
  • 2.5"
  • USB Powered
  • SecretZone
  • SafetyKey
  • Power Saving Mode
  • Warranty: 3 Years
  • 17.5mm x 111.0mm x 82.0mm
  • Powered by USB
  • 5400RPM
SAMSUNG SecretZone™ and SafetyKey™
SecretZone is a virtual drive function that provides encryption of personal files and folders for data security. You can keep your most important content private in SecretZone. And with SAMSUNG SfetyKey™, you can protect your precious content simply by setting a password as part of SAMSUNG's Auto Backup function. Your security worries are over.
  • Windows® XP, Windows Vista®, Windows 7 Mac OS® X Tiger®, Leopard®, Snow Leopard™ (requires reformatting)
Image gallery
Select any thumbnail below to view a larger image.
Samsung S2 Portable HXMU010EA - hard drive - 1 TB - Hi-Speed USB
Hard drive - external
2.5"
8.2 cm x 11.1 cm x 2 cm
196 g
Enclosure Colour
Piano black
1 TB
Interface Type
Hi-Speed USB
Data Transfer Rate
480 Mbps
Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.4.8 or later
Microsoft Certification
Compatible with Windows 7
3 years warranty
8.2 cm
11.1 cm
2 cm
196 g
Enclosure Colour
Piano black
Hard Drive
2.5"
1 TB
Interface Type
Hi-Speed USB
Samsung Auto Backup, SafetyKey, SecretZone
Performance
Interface Transfer Rate
480 Mbps
1 x Hi-Speed USB - 4 PIN USB Type A
Software Included
Drivers & Utilities
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
feature value
Form Factor 2.5"
Capacity 1TB
Interface USB 2.0
Brand Samsung
Stock Status In Stock
Price Range Inc VAT 50 - 100
