Roth Audio CHARLiE 2.1 Desktop Music System - Black
The CHARLiE 2.1 is a two-speaker set-up (2) with a subwoofer (1).
The CHARLiE 2.1 system comes complete with the RothDock meaning - thanks to the wireless receiver built into the base of the CHARLiE subwoofer - a wire-free connection between your docked iPhone and iPod and the speakers/subwoofer - they can be up to 15m apart. In addition, with the USB input and the auxiliary input, this system will work with anything you like, but specifically computers, laptops, etc., where your music is likely to be stored.
The runaway success of online music services, such as iTunes and Spotify, means more and more music is trapped on flash drives and hard drives. This all makes fine sense... until you listen to tunes via the speaker systems generally found built into the sexy-looking, but increasingly compact Mac, PCs and laptops. The resulting audio from these built-in speakers tend to come ladled with ASBO-deserving treble, search in vain for convincing midrange, and are utter strangers to the valley town known as Bass. "Enter stage right CHARLiE 2.1".
With the quality audio reproduction in mind the CHARLiE 2.1 System would not sound or look out of place for those who mix there own tunes at home or indeed in the pro arena - a true compliment to any audio software packages.
The RothDock supplied is also officially both a Made for iPod and Works with iPhone certified product, so there is no need to adjust your iPhone settings to airplane mode. Turn It Up.
Main Features
- 25 watts Stereo Speaker plus Sub Woofer Setup
- Sub Woofer features integrated audio and input select controls
- Comes with RothDock Wireless Dock
- 3.5mm Auxiliary Audio Input
- USB Input
Mail Online Review
"The chances are you've spent several hundred pounds on a decent computer, so why settle for tinny, limited speakers. You wouldn't buy a sports car with the engine of a Mini Metro would you?
So forget the dedicated iPod docks out there, buy one of these, bring your PC to life, plug in your iPod to boot and annoy the hell out of your neighbours."
Select any thumbnail below to view a larger image.
